[postgis-tickets] [PostGIS] #3092: Slow performance of geometry_columns in PostGIS >= 2
PostGIS trac at osgeo.org
Fri Apr 24 14:24:53 PDT 2015
  Reporter:  rouault      |      Owner:  pramsey
      Type:  enhancement  |     Status:  new
  Priority:  high         |  Milestone:  PostGIS 2.1.8
 Component:  postgis      |    Version:  2.0.x
Resolution:               |   Keywords:
Comment (by robe):
 pramsey at a glance I see a problem.  You don't want to use a WITH clause
 here because it will force having to query all rows before you can filter.
 I suspect that won't scale with large numbers of tables.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3092#comment:9>
