[postgis-tickets] [PostGIS] #3092: Slow performance of geometry_columns in PostGIS >= 2
PostGIS trac at osgeo.org
Sat Apr 25 18:11:55 PDT 2015
  Reporter:  rouault      |      Owner:  pramsey
      Type:  enhancement  |     Status:  new
  Priority:  high         |  Milestone:  PostGIS 2.1.8
 Component:  postgis      |    Version:  2.0.x
Resolution:               |   Keywords:
Comment (by robe):
 committed change at r13446 to trunk.
 I'm going to do some tests on lower versions of PostgreSQL to make sure
 performance is just as good.  Only did testing on 9.4 w 64-bit windows.
 If performance is good, I'll backport this to 2.1 and add a regression
 test.
 strk -- you know that interrupatability voodoo you got going that does
 timing -- is it possible to reuse the timing logic to incorporate a timing
 test for this?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3092#comment:17>
