[postgis-tickets] [PostGIS] #3103: geometry_columns, find_srid performance regress tests
PostGIS trac at osgeo.org
Sun Apr 26 08:55:42 PDT 2015
 Reporter:  robe     |      Owner:  pramsey
     Type:  task     |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 2.2.0
Component:  postgis  |    Version:  2.1.x
 Keywords:           |
 We need to add a test for both checking correctness and performance of
 querying geometry_columns and using find_srid. Per issues uncovered in
 #3092 and #2365.
 The way the planner behaves has changed over time too so simply assuming
 because performance is good in pg version x for a particular view it will
 be good in pg version whatever is fraught with problems.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3103>
