[postgis-tickets] [PostGIS] #3092: Slow performance of geometry_columns in PostGIS >= 2
PostGIS trac at osgeo.org
Mon Apr 27 03:58:59 PDT 2015
  Reporter:  rouault      |      Owner:  robe
      Type:  enhancement  |     Status:  closed
  Priority:  high         |  Milestone:  PostGIS 2.1.8
 Component:  postgis      |    Version:  2.0.x
Resolution:  fixed        |   Keywords:  history
Comment (by strk):
 Robe the interrupt hack creates a table writing in the value of now() and
 then checks the value again against now() after performing its thing. It's
 not perfect. Ideally it should also consider some kind of "standard time"
 it takes to do things so to use "relative time".
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3092#comment:24>
