[postgis-tickets] [PostGIS] #2382: Can't upgrade postgis ERROR: attempt to redefine parameter "postgis.backend"
PostGIS trac at osgeo.org
Tue Aug 11 07:39:30 PDT 2015
"postgis.backend"
  Reporter:  robe                   |      Owner:  pramsey
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 2.2.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:  fixed                  |   Keywords:
Changes (by pramsey):
 * status:  reopened => closed
 * resolution:   => fixed
Comment:
 Re-applied the GUC def'n patch at r13902, which allows me to upgrade in a
 "dirty" session that already has the old library loaded in it, at the cost
 of locking the GUC value to the old one until such time as the user re-
 connects to a clean session. A warning is emitted.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2382#comment:40>
