[postgis-tickets] [PostGIS] #3238: SFCGAL tests failing
PostGIS trac at osgeo.org
Wed Aug 19 07:53:19 PDT 2015
  Reporter:  strk     |      Owner:  colivier
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 2.2.0
 Component:  sfcgal   |    Version:  trunk
Resolution:  fixed    |   Keywords:  testsing
Comment (by strk):
 Otherwise it makes it usable but results in a broken session until you
 reconnect...
 I wonder if there's any command we may run to force reconnection, from
 sql.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3238#comment:17>
