[postgis-tickets] [PostGIS] #3220: Mingw failure on cluster test
PostGIS trac at osgeo.org
Sun Aug 23 08:18:34 PDT 2015
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.2.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Changes (by dbaston):
 * cc: dbaston (added)
Comment:
 OK, working backwards, next place I would check to see if the tolerance is
 correct is lwgeom_accum.c, line 133.  If the value is correct here, then I
 would wonder if the Datum holding the tolerance is being freed before the
 value is actually read from it.  Does this Datum need to be copied into a
 different MemoryContext?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3220#comment:12>
