[postgis-tickets] [PostGIS] #3107: [sfcgal]crash in straight_skeleton
PostGIS trac at osgeo.org
Wed Aug 26 13:17:42 PDT 2015
  Reporter:  cactusbone  |      Owner:  colivier
      Type:  defect      |     Status:  closed
  Priority:  critical    |  Milestone:  PostGIS SFCGAL
 Component:  sfcgal      |    Version:  2.1.x
Resolution:  fixed       |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
 * milestone:  PostGIS 2.2.0 => PostGIS SFCGAL
Comment:
 Switched to PosTGIS SFCGAL.  Looks like it doesn't crash anymor with
 1.2.0dev in SFCGAL/git master.
 running on:
 POSTGIS="2.2.0dev r13992" GEOS="3.5.0-CAPI-1.9.0 r4088" SFCGAL="1.2.0"
 PROJ="Rel. 4.9.1, 04 March 2015" GDAL="GDAL 2.0.0, released 2015/06/14
 GDAL_DATA not found" LIBXML="2.7.8" LIBJSON="0.12" RASTER
 NOTICE:  During straight_skeleton(A) :
 NOTICE:    with A: POLYGON((5389037/4
 7714562210592195/1073741824,723311775491031/536870912
 1928643832929321/268435456,5786525213592125/4294967296
 7714566516296909/1073741824,1446628780104745/1073741824
 7714564293651333/1073741824,5786530668200591/4294967296 38572
 ERROR:  straight skeleton of Polygon with touching interior rings is not
 implemented
 ********** Error **********
 implemented
 SQL state: XX000
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3107#comment:5>
