[postgis-tickets] r14464 - I don't think config.rpath belongs in the repo
Sandro Santilli strk at keybit.net
Tue Dec 1 01:29:02 PST 2015
Author: strk
Date: 2015-12-01 01:29:02 -0800 (Tue, 01 Dec 2015)
New Revision: 14464
Removed:
   trunk/config.rpath
Deleted: trunk/config.rpath
--- trunk/config.rpath	2015-12-01 09:28:56 UTC (rev 14463)
+++ trunk/config.rpath	2015-12-01 09:29:02 UTC (rev 14464)
@@ -1,666 +0,0 @@
-#! /bin/sh
-# Output a system dependent set of variables, describing how to set the
-# run time search path of shared libraries in an executable.
-#   Copyright 1996-2007 Free Software Foundation, Inc.
-#   Taken from GNU libtool, 2001
-#   Originally by Gordon Matzigkeit <gord at gnu.ai.mit.edu>, 1996
-#   This file is free software; the Free Software Foundation gives
-#   unlimited permission to copy and/or distribute it, with or without
-#   modifications, as long as this notice is preserved.
-# The first argument passed to this file is the canonical host specification,
-#    CPU_TYPE-MANUFACTURER-OPERATING_SYSTEM
-# or
-#    CPU_TYPE-MANUFACTURER-KERNEL-OPERATING_SYSTEM
-# The environment variables CC, GCC, LDFLAGS, LD, with_gnu_ld
-# should be set by the caller.
-# The set of defined variables is at the end of this script.
-# Known limitations:
-# - On IRIX 6.5 with CC="cc", the run time search patch must not be longer
-#   than 256 bytes, otherwise the compiler driver will dump core. The only
-#   known workaround is to choose shorter directory names for the build
-#   directory and/or the installation directory.
-# All known linkers require a `.a' archive for static linking (except MSVC,
-# which needs '.lib').
-libext=a
-shrext=.so
-host="$1"
-host_cpu=`echo "$host" | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\1/'`
-host_vendor=`echo "$host" | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\2/'`
-host_os=`echo "$host" | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\3/'`
-# Code taken from libtool.m4's _LT_CC_BASENAME.
-for cc_temp in $CC""; do
-  case $cc_temp in
-    compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
-    distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
-    *) break;;
-  esac
-done
-cc_basename=`echo "$cc_temp" | sed -e 's%^.*/%%'`
-# Code taken from libtool.m4's AC_LIBTOOL_PROG_COMPILER_PIC.
-wl=
-if test "$GCC" = yes; then
-  wl='-Wl,'
-else
-  case "$host_os" in
-    aix*)
-      wl='-Wl,'
-    darwin*)
-      case $cc_basename in
-        xlc*)
-          wl='-Wl,'
-      esac
-    mingw* | cygwin* | pw32* | os2*)
-    hpux9* | hpux10* | hpux11*)
-      wl='-Wl,'
-    irix5* | irix6* | nonstopux*)
-      wl='-Wl,'
-    newsos6)
-    linux* | k*bsd*-gnu)
-        icc* | ecc*)
-          wl='-Wl,'
-        pgcc | pgf77 | pgf90)
-          wl='-Wl,'
-        ccc*)
-          wl='-Wl,'
-        como)
-          wl='-lopt='
-          case `$CC -V 2>&1 | sed 5q` in
-            *Sun\ C*)
-              wl='-Wl,'
-          esac
-      esac
-    osf3* | osf4* | osf5*)
-      wl='-Wl,'
-    rdos*)
-    solaris*)
-      wl='-Wl,'
-    sunos4*)
-      wl='-Qoption ld '
-    sysv4 | sysv4.2uw2* | sysv4.3*)
-      wl='-Wl,'
-    sysv4*MP*)
-    sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
-      wl='-Wl,'
-    unicos*)
-      wl='-Wl,'
-    uts4*)
-  esac
-fi
-# Code taken from libtool.m4's AC_LIBTOOL_PROG_LD_SHLIBS.
-hardcode_libdir_flag_spec=
-hardcode_libdir_separator=
-hardcode_direct=no
-hardcode_minus_L=no
-case "$host_os" in
-  cygwin* | mingw* | pw32*)
-    # FIXME: the MSVC++ port hasn't been tested in a loooong time
-    # When not using gcc, we currently assume that we are using
-    # Microsoft Visual C++.
-    if test "$GCC" != yes; then
-      with_gnu_ld=no
-    fi
-  interix*)
-    # we just hope/assume this is gcc and not c89 (= MSVC++)
-    with_gnu_ld=yes
-  openbsd*)
-    with_gnu_ld=no
-esac
-ld_shlibs=yes
-if test "$with_gnu_ld" = yes; then
-  # Set some defaults for GNU ld with shared library support. These
-  # are reset later if shared libraries are not supported. Putting them
-  # here allows them to be overridden if necessary.
-  # Unlike libtool, we use -rpath here, not --rpath, since the documented
-  # option of GNU ld is called -rpath, not --rpath.
-  hardcode_libdir_flag_spec='${wl}-rpath ${wl}$libdir'
-    aix3* | aix4* | aix5*)
-      # On AIX/PPC, the GNU linker is very broken
-      if test "$host_cpu" != ia64; then
-        ld_shlibs=no
-      fi
-    amigaos*)
-      hardcode_libdir_flag_spec='-L$libdir'
-      hardcode_minus_L=yes
-      # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
-      # that the semantics of dynamic libraries on AmigaOS, at least up
-      # to version 4, is to share data among multiple programs linked
-      # with the same dynamic library.  Since this doesn't match the
-      # behavior of shared libraries on other platforms, we cannot use
-      # them.
-      ld_shlibs=no
-    beos*)
-      if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
-      else
-        ld_shlibs=no
-      fi
-      # hardcode_libdir_flag_spec is actually meaningless, as there is
-      # no search path for DLLs.
-      if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
-      else
-        ld_shlibs=no
-      fi
-    interix[3-9]*)
-      hardcode_direct=no
-      hardcode_libdir_flag_spec='${wl}-rpath,$libdir'
-    gnu* | linux* | k*bsd*-gnu)
-      else
-        ld_shlibs=no
-      fi
-    netbsd*)
-    solaris*)
-      if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
-        ld_shlibs=no
-      elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
-      else
-        ld_shlibs=no
-      fi
-    sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX*)
-      case `$LD -v 2>&1` in
-        *\ [01].* | *\ 2.[0-9].* | *\ 2.1[0-5].*)
-          ld_shlibs=no
-            hardcode_libdir_flag_spec='`test -z "$SCOABSPATH" && echo ${wl}-rpath,$libdir`'
-          else
-            ld_shlibs=no
-          fi
-      esac
-    sunos4*)
-      hardcode_direct=yes
-      else
-        ld_shlibs=no
-      fi
-  esac
-  if test "$ld_shlibs" = no; then
-  fi
-else
-    aix3*)
-      # Note: this linker hardcodes the directories in LIBPATH if there
-      # are no directories specified by -L.
-      if test "$GCC" = yes; then
-        # Neither direct hardcoding nor static linking is supported with a
-        # broken collect2.
-        hardcode_direct=unsupported
-      fi
-    aix4* | aix5*)
-      if test "$host_cpu" = ia64; then
-        # On IA64, the linker does run time linking by default, so we don't
-        # have to do anything special.
-        aix_use_runtimelinking=no
-      else
-        # Test if we are trying to use run time linking or normal
-        # AIX style linking. If -brtl is somewhere in LDFLAGS, we
-        # need to do runtime linking.
-        case $host_os in aix4.[23]|aix4.[23].*|aix5*)
-          for ld_flag in $LDFLAGS; do
-            if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
-              aix_use_runtimelinking=yes
-              break
-            fi
-          done
-        esac
-      fi
-      hardcode_libdir_separator=':'
-        case $host_os in aix4.[012]|aix4.[012].*)
-          collect2name=`${CC} -print-prog-name=collect2`
-          if test -f "$collect2name" && \
-            strings "$collect2name" | grep resolve_lib_name >/dev/null
-          then
-            # We have reworked collect2
-          else
-            # We have old collect2
-          fi
-        esac
-      fi
-      # Begin _LT_AC_SYS_LIBPATH_AIX.
-      echo 'int main () { return 0; }' > conftest.c
-      ${CC} ${LDFLAGS} conftest.c -o conftest
-      aix_libpath=`dump -H conftest 2>/dev/null | sed -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
-      if test -z "$aix_libpath"; then
-        aix_libpath=`dump -HX64 conftest 2>/dev/null | sed -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
-      fi
-        aix_libpath="/usr/lib:/lib"
-      fi
-      rm -f conftest.c conftest
-      # End _LT_AC_SYS_LIBPATH_AIX.
-      if test "$aix_use_runtimelinking" = yes; then
-        hardcode_libdir_flag_spec='${wl}-blibpath:$libdir:'"$aix_libpath"
-      else
-          hardcode_libdir_flag_spec='${wl}-R $libdir:/usr/lib:/lib'
-        else
-        fi
-      fi
-    amigaos*)
-      # see comment about different semantics on the GNU ld section
-      ld_shlibs=no
-    bsdi[45]*)
-      hardcode_libdir_flag_spec=' '
-      libext=lib
-    darwin* | rhapsody*)
-      if test "$GCC" = yes ; then
-      else
-          xlc*)
-            ld_shlibs=no
-        esac
-      fi
-    dgux*)
-    freebsd1*)
-      ld_shlibs=no
-    freebsd2.2*)
-      hardcode_libdir_flag_spec='-R$libdir'
-    freebsd2*)
-    freebsd* | dragonfly*)
-    hpux9*)
-      hardcode_libdir_flag_spec='${wl}+b ${wl}$libdir'
-      hardcode_libdir_separator=:
-      # hardcode_minus_L: Not really in the search PATH,
-      # but as the default location of the library.
-    hpux10*)
-      if test "$with_gnu_ld" = no; then
-      fi
-    hpux11*)
-        case $host_cpu in
-          hppa*64*|ia64*)
-        esac
-      fi
-    netbsd*)
-    newsos6)
-    openbsd*)
-      if test -f /usr/libexec/ld.so; then
-        if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
-        else
-            openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
-          esac
-        fi
-      else
-        ld_shlibs=no
-      fi
-    os2*)
-    osf3*)
-    osf4* | osf5*)
-      else
-        # Both cc and cxx compiler support -rpath directly
-        hardcode_libdir_flag_spec='-rpath $libdir'
-      fi
-    solaris*)
-    sunos4*)
-    sysv4)
-      case $host_vendor in
-        sni)
-          hardcode_direct=yes # is this really true???
-        siemens)
-        motorola)
-          hardcode_direct=no #Motorola manual says yes, but my tests say they lie
-      esac
-    sysv4.3*)
-    sysv4*MP*)
-      if test -d /usr/nec; then
-        ld_shlibs=yes
-      fi
-    sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7* | sco3.2v5.0.[024]*)
-    sysv5* | sco3.2v5* | sco5v6*)
-      hardcode_libdir_flag_spec='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
-    uts4*)
-      ld_shlibs=no
-  esac
-fi
-# Check dynamic linker characteristics
-# Code taken from libtool.m4's AC_LIBTOOL_SYS_DYNAMIC_LINKER.
-# Unlike libtool.m4, here we don't care about _all_ names of the library, but
-# only about the one the linker finds when passed -lNAME. This is the last
-# element of library_names_spec in libtool.m4, or possibly two of them if the
-# linker has special search rules.
-library_names_spec=      # the last element of library_names_spec in libtool.m4
-libname_spec='lib$name'
-case "$host_os" in
-  aix3*)
-    library_names_spec='$libname.a'
-  aix4* | aix5*)
-    library_names_spec='$libname$shrext'
-  amigaos*)
-  beos*)
-  bsdi[45]*)
-    shrext=.dll
-    library_names_spec='$libname.dll.a $libname.lib'
-    shrext=.dylib
-  dgux*)
-  freebsd1*)
-      freebsd[123]*)
-        library_names_spec='$libname$shrext$versuffix' ;;
-        library_names_spec='$libname$shrext' ;;
-    esac
-  gnu*)
-    case $host_cpu in
-      ia64*)
-        shrext=.so
-      hppa*64*)
-        shrext=.sl
-        shrext=.sl
-    esac
-  interix[3-9]*)
-      irix5* | nonstopux*)
-        libsuff= shlibsuff=
-        case $LD in
-          *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ") libsuff= shlibsuff= ;;
-          *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ") libsuff=32 shlibsuff=N32 ;;
-          *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ") libsuff=64 shlibsuff=64 ;;
-          *) libsuff= shlibsuff= ;;
-        esac
-    esac
-  linux*oldld* | linux*aout* | linux*coff*)
-  knetbsd*-gnu)
-  netbsd*)
-  newsos6)
-  nto-qnx*)
-  openbsd*)
-  os2*)
-    libname_spec='$name'
-    shrext=.dll
-  rdos*)
-  solaris*)
-  sunos4*)
-  sysv4 | sysv4.3*)
-  sysv4*MP*)
-  sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
-  uts4*)
-esac
-sed_quote_subst='s/\(["`$\\]\)/\\\1/g'
-escaped_wl=`echo "X$wl" | sed -e 's/^X//' -e "$sed_quote_subst"`
-shlibext=`echo "$shrext" | sed -e 's,^\.,,'`
-escaped_libname_spec=`echo "X$libname_spec" | sed -e 's/^X//' -e "$sed_quote_subst"`
-escaped_library_names_spec=`echo "X$library_names_spec" | sed -e 's/^X//' -e "$sed_quote_subst"`
-escaped_hardcode_libdir_flag_spec=`echo "X$hardcode_libdir_flag_spec" | sed -e 's/^X//' -e "$sed_quote_subst"`
-LC_ALL=C sed -e 's/^\([a-zA-Z0-9_]*\)=/acl_cv_\1=/' <<EOF
-# How to pass a linker flag through the compiler.
-wl="$escaped_wl"
-# Static library suffix (normally "a").
-libext="$libext"
-# Shared library suffix (normally "so").
-shlibext="$shlibext"
-# Format of library name prefix.
-libname_spec="$escaped_libname_spec"
-# Library names that the linker finds when passed -lNAME.
-library_names_spec="$escaped_library_names_spec"
-# Flag to hardcode \$libdir into a binary during linking.
-# This must work even if \$libdir does not exist.
-hardcode_libdir_flag_spec="$escaped_hardcode_libdir_flag_spec"
-# Whether we need a single -rpath flag with a separated argument.
-hardcode_libdir_separator="$hardcode_libdir_separator"
-# Set to yes if using DIR/libNAME.so during linking hardcodes DIR into the
-# resulting binary.
-hardcode_direct="$hardcode_direct"
-# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
-hardcode_minus_L="$hardcode_minus_L"
-EOF
