[postgis-tickets] r14466 - #3365, remove code paths for POSTGIS_GEOS_VERSION < 33
Daniel Baston dbaston at gmail.com
Tue Dec 1 15:16:41 PST 2015
Author: dbaston
Date: 2015-12-01 15:16:41 -0800 (Tue, 01 Dec 2015)
New Revision: 14466
   trunk/liblwgeom/cunit/cu_clean.c
   trunk/liblwgeom/cunit/cu_node.c
   trunk/liblwgeom/cunit/cu_split.c
   trunk/liblwgeom/lwgeom_geos.c
   trunk/liblwgeom/lwgeom_geos_clean.c
   trunk/liblwgeom/lwgeom_geos_node.c
   trunk/postgis/lwgeom_geos.c
   trunk/postgis/lwgeom_geos_clean.c
   trunk/postgis/lwgeom_geos_relatematch.c
   trunk/raster/rt_core/rt_geometry.c
   trunk/raster/test/cunit/cu_raster_geometry.c
Modified: trunk/liblwgeom/cunit/cu_clean.c
--- trunk/liblwgeom/cunit/cu_clean.c	2015-12-01 10:52:02 UTC (rev 14465)
+++ trunk/liblwgeom/cunit/cu_clean.c	2015-12-01 23:16:41 UTC (rev 14466)
@@ -41,7 +41,6 @@
 static void test_lwgeom_make_valid(void)
-#if POSTGIS_GEOS_VERSION >= 33
 	LWGEOM *gin, *gout, *gexp;
 	char *ewkt;
@@ -148,8 +147,6 @@
 	lwgeom_free(gout);
 	lwgeom_free(gin);
-#endif /* POSTGIS_GEOS_VERSION >= 33 */
 /* TODO: add more tests ! */
Modified: trunk/liblwgeom/cunit/cu_node.c
--- trunk/liblwgeom/cunit/cu_node.c	2015-12-01 10:52:02 UTC (rev 14465)
+++ trunk/liblwgeom/cunit/cu_node.c	2015-12-01 23:16:41 UTC (rev 14466)
@@ -18,7 +18,6 @@
 static void test_lwgeom_node(void)
 	LWGEOM *in, *out;
 	const char *wkt;
 	char *tmp;
@@ -57,7 +56,6 @@
 "MULTILINESTRING((0 0,2.5 2.5),(0 5,2.5 2.5),(22 0,20 0),(20 0,12 0,11 0,10 0),(10 0,5 5,2.5 2.5),(2.5 2.5,5 0))",
 		tmp);
 	lwfree(tmp); lwgeom_free(out); lwgeom_free(in);
Modified: trunk/liblwgeom/cunit/cu_split.c
--- trunk/liblwgeom/cunit/cu_split.c	2015-12-01 10:52:02 UTC (rev 14465)
+++ trunk/liblwgeom/cunit/cu_split.c	2015-12-01 23:16:41 UTC (rev 14466)
@@ -18,7 +18,6 @@
 static void test_lwline_split_by_point_to(void)
 	LWLINE *line;
 	LWPOINT *point;
 	LWMLINE *coll;
@@ -76,8 +75,6 @@
 	lwcollection_free((LWCOLLECTION*)coll);
 	lwline_free(line);
 static void test_lwgeom_split(void)
Modified: trunk/liblwgeom/lwgeom_geos.c
--- trunk/liblwgeom/lwgeom_geos.c	2015-12-01 10:52:02 UTC (rev 14465)
+++ trunk/liblwgeom/lwgeom_geos.c	2015-12-01 23:16:41 UTC (rev 14466)
@@ -227,15 +227,6 @@
 			LWDEBUGF(4, "Point: %g,%g", p2d->x, p2d->y);
-#if POSTGIS_GEOS_VERSION < 33
-		/* Make sure we don't pass any infinite values down into GEOS */
-		/* GEOS 3.3+ is supposed to  handle this stuff OK */
-		if ( isinf(p2d->x) || isinf(p2d->y) || (dims == 3 && isinf(p3d->z)) )
-			lwerror("Infinite coordinate value found in geometry.");
-		if ( isnan(p2d->x) || isnan(p2d->y) || (dims == 3 && isnan(p3d->z)) )
-			lwerror("NaN coordinate value found in geometry.");
-#endif
 		GEOSCoordSeq_setX(sq, i, p2d->x);
 		GEOSCoordSeq_setY(sq, i, p2d->y);
@@ -349,23 +340,13 @@
 		LWPOLY *lwpoly = NULL;
 		LWLINE *lwl = NULL;
 		LWCOLLECTION *lwc = NULL;
-		POINTARRAY *pa = NULL;
-#endif
 	case POINTTYPE:
 		lwp = (LWPOINT *)lwgeom;
 		if ( lwgeom_is_empty(lwgeom) )
-			pa = ptarray_construct_empty(lwgeom_has_z(lwgeom), lwgeom_has_m(lwgeom), 2);
-			sq = ptarray_to_GEOSCoordSeq(pa);
-			shell = GEOSGeom_createLinearRing(sq);
-			g = GEOSGeom_createPolygon(shell, NULL, 0);
-#else
 			g = GEOSGeom_createEmptyPolygon();
-#endif
 		else
@@ -401,14 +382,7 @@
 		lwpoly = (LWPOLY *)lwgeom;
-			POINTARRAY *pa = ptarray_construct_empty(lwgeom_has_z(lwgeom), lwgeom_has_m(lwgeom), 2);
-#else
-#endif
 		else
@@ -1413,14 +1387,6 @@
 LWGEOM*
 lwgeom_snap(const LWGEOM* geom1, const LWGEOM* geom2, double tolerance)
-	lwerror("The GEOS version this lwgeom library "
-	        "was compiled against (%d) doesn't support "
-	        "'Snap' function (3.3.0+ required)",
-	        POSTGIS_GEOS_VERSION);
-	return NULL;
-#else /* POSTGIS_GEOS_VERSION >= 33 */
 	int srid, is3d;
 	GEOSGeometry *g1, *g2, *g3;
 	LWGEOM* out;
@@ -1470,20 +1436,11 @@
 	GEOSGeom_destroy(g3);
 	return out;
 LWGEOM*
 lwgeom_sharedpaths(const LWGEOM* geom1, const LWGEOM* geom2)
-	lwerror("The GEOS version this postgis binary "
-	        "'SharedPaths' function (3.3.0+ required)",
-	return NULL;
 	LWGEOM *out;
 	int is3d, srid;
@@ -1532,15 +1489,11 @@
 	return out;
 LWGEOM*
 lwgeom_offsetcurve(const LWLINE *lwline, double size, int quadsegs, int joinStyle, double mitreLimit)
-#if POSTGIS_GEOS_VERSION < 32
-	lwerror("lwgeom_offsetcurve: GEOS 3.2 or higher required");
-#else
 	GEOSGeometry *g1, *g3;
 	LWGEOM *lwgeom_result;
 	LWGEOM *lwgeom_in = lwline_as_lwgeom(lwline);
@@ -1554,14 +1507,8 @@
 		return NULL;
-	/* Size is always positive for GEOSSingleSidedBuffer, and a flag determines left/right */
-	g3 = GEOSSingleSidedBuffer(g1, size < 0 ? -size : size,
-	                           quadsegs, joinStyle, mitreLimit,
-	                           size < 0 ? 0 : 1);
-#else
 	g3 = GEOSOffsetCurve(g1, size, quadsegs, joinStyle, mitreLimit);
-#endif
 	/* Don't need input geometry anymore */
 	GEOSGeom_destroy(g1);
@@ -1584,8 +1531,6 @@
 	return lwgeom_result;
-#endif /* POSTGIS_GEOS_VERSION < 32 */
 LWTIN *lwtin_from_geos(const GEOSGeometry *geom, int want3d) {
Modified: trunk/liblwgeom/lwgeom_geos_clean.c
--- trunk/liblwgeom/lwgeom_geos_clean.c	2015-12-01 10:52:02 UTC (rev 14465)
+++ trunk/liblwgeom/lwgeom_geos_clean.c	2015-12-01 23:16:41 UTC (rev 14466)
@@ -381,7 +381,6 @@
 	return noded;
  * We expect initGEOS being called already.
  * Will return NULL on error (expect error handler being called by then)
@@ -1066,5 +1065,3 @@
 	return lwgeom_out;
Modified: trunk/liblwgeom/lwgeom_geos_node.c
--- trunk/liblwgeom/lwgeom_geos_node.c	2015-12-01 10:52:02 UTC (rev 14465)
+++ trunk/liblwgeom/lwgeom_geos_node.c	2015-12-01 23:16:41 UTC (rev 14466)
@@ -85,13 +85,6 @@
 static LWGEOM*
 lwgeom_extract_unique_endpoints(const LWGEOM* lwg)
-	        "'GEOSUnaryUnion' function (3.3.0+ required)",
-	return NULL;
 	LWGEOM* ret;
 	GEOSGeometry *gepu;
 	LWMPOINT *epall = lwgeom_extract_endpoints(lwg);
@@ -120,7 +113,6 @@
 	return ret;
 /* exported */
@@ -128,13 +120,6 @@
 LWGEOM*
 lwgeom_node(const LWGEOM* lwgeom_in)
-	return NULL;
 	GEOSGeometry *g1, *gu, *gm;
 	LWGEOM *ep, *lines;
 	LWCOLLECTION *col, *tc;
@@ -254,6 +239,5 @@
 	lines->srid = lwgeom_in->srid;
 	return (LWGEOM*)lines;
Modified: trunk/postgis/lwgeom_geos.c
--- trunk/postgis/lwgeom_geos.c	2015-12-01 10:52:02 UTC (rev 14465)
+++ trunk/postgis/lwgeom_geos.c	2015-12-01 23:16:41 UTC (rev 14466)
@@ -116,13 +116,6 @@
 PG_FUNCTION_INFO_V1(hausdorffdistance);
 Datum hausdorffdistance(PG_FUNCTION_ARGS)
-	lwpgerror("The GEOS version this PostGIS binary "
-	        "'ST_HausdorffDistance' function (3.2.0+ required)",
-	PG_RETURN_NULL();
-#else
 	GSERIALIZED *geom1;
 	GSERIALIZED *geom2;
 	GEOSGeometry *g1;
@@ -169,7 +162,6 @@
 	PG_FREE_IF_COPY(geom2, 1);
 	PG_RETURN_FLOAT8(result);
-#endif
@@ -182,13 +174,6 @@
 PG_FUNCTION_INFO_V1(hausdorffdistancedensify);
 Datum hausdorffdistancedensify(PG_FUNCTION_ARGS)
-	PG_RETURN_NULL();
-#else
 	GSERIALIZED *geom1;
 	GSERIALIZED *geom2;
 	GEOSGeometry *g1;
@@ -236,7 +221,6 @@
-#endif
@@ -250,7 +234,6 @@
 PG_FUNCTION_INFO_V1(pgis_union_geometry_array);
 Datum pgis_union_geometry_array(PG_FUNCTION_ARGS)
 	** For GEOS >= 3.3, use the new UnaryUnion functionality to merge the
@@ -436,297 +419,6 @@
 	PG_RETURN_POINTER(gser_out);
-#else
-/* For GEOS < 3.3, use the old CascadedUnion function for polygons and
-   brute force two-by-two for other types. */
-	ArrayType *array;
-	int is3d = 0;
-	int nelems = 0;
-	GSERIALIZED *result = NULL;
-	GSERIALIZED *pgis_geom = NULL;
-	GEOSGeometry * g1 = NULL;
-	GEOSGeometry * g2 = NULL;
-	GEOSGeometry * geos_result = NULL;
-	int srid = SRID_UNKNOWN;
-	int count;
-	ArrayIterator iterator;
-	Datum value;
-	bool isnull;
-	int gotsrid = 0;
-	int allpolys = 1;
-	if ( PG_ARGISNULL(0) )
-		PG_RETURN_NULL();
-	array = PG_GETARG_ARRAYTYPE_P(0);
-	nelems = ArrayGetNItems(ARR_NDIM(array), ARR_DIMS(array));
-	POSTGIS_DEBUGF(3, "%s: number of elements: %d", __func__, nelems);
-	/* Zero elements in array? return NULL */
-	if ( nelems == 0 )
-		PG_RETURN_NULL();
-	** First, see if all our elements are POLYGON/MULTIPOLYGON
-	** If they are, we can use UnionCascaded for faster results.
-	count = 0;
-#if POSTGIS_PGSQL_VERSION >= 95
-	iterator = array_create_iterator(array, 0, NULL);
-#else
-	iterator = array_create_iterator(array, 0);
-#endif
-	while( array_iterate(iterator, &value, &isnull) )
-		GSERIALIZED *pggeom;
-		int pgtype;
-		/* Don't do anything for NULL values */
-		if ( isnull )
-			continue;
-		pggeom = (GSERIALIZED *)DatumGetPointer(value);
-		pgtype = gserialized_get_type(pggeom);
-		if ( ! gotsrid ) /* Initialize SRID */
-			srid = gserialized_get_srid(pggeom);
-			gotsrid = 1;
-			if ( gserialized_has_z(pggeom) ) is3d = 1;
-		else
-			error_if_srid_mismatch(srid, gserialized_get_srid(pggeom));
-		if ( pgtype != POLYGONTYPE && pgtype != MULTIPOLYGONTYPE )
-			allpolys = 0;
-			break;
-		count++;
-	array_free_iterator(iterator);
-	/* All the components are null? Return null */
-	if ( count == 0 )
-		PG_RETURN_NULL();
-	/* Just one non-null component? Return that */
-	if ( count == 1 && nelems == 1 )
-		PG_RETURN_POINTER((GSERIALIZED *)(ARR_DATA_PTR(array)));
-	/* Ok, we really need geos now ;) */
-	initGEOS(lwpgnotice, lwgeom_geos_error);
-	if ( allpolys )
-		** Everything is polygonal, so let's run the cascaded polygon union!
-		int geoms_size = nelems;
-		int curgeom = 0;
-		GEOSGeometry **geoms = NULL;
-		geoms = palloc(sizeof(GEOSGeometry *) * geoms_size);
-		** We need to convert the array of GSERIALIZED into a GEOS MultiPolygon.
-		** First make an array of GEOS Polygons.
-#else
-#endif
-			GEOSGeometry* g;
-			int pgtype;
-			if ( isnull )
-				continue;
-			pggeom = (GSERIALIZED *)(ARR_DATA_PTR(array)+offset);
-			if ( pgtype == POLYGONTYPE )
-				if ( curgeom == geoms_size )
-					geoms_size *= 2;
-					geoms = repalloc( geoms, sizeof(GEOSGeom) * geoms_size );
-				g = (GEOSGeometry *)POSTGIS2GEOS(pggeom);
-				if ( 0 == g )   /* exception thrown at construction */
-					/* TODO: release GEOS allocated memory ! */
-					HANDLE_GEOS_ERROR("One of the geometries in the set "
-				                    "could not be converted to GEOS");
-					PG_RETURN_NULL();
-				geoms[curgeom] = g;
-				curgeom++;
-			if ( pgtype == MULTIPOLYGONTYPE )
-				int j = 0;
-				LWMPOLY *lwmpoly = (LWMPOLY*)lwgeom_from_gserialized(pggeom);;
-				for ( j = 0; j < lwmpoly->ngeoms; j++ )
-					GEOSGeometry* g;
-						geoms_size *= 2;
-					/* This builds a LWPOLY on top of the serialized form */
-					g = LWGEOM2GEOS(lwpoly_as_lwgeom(lwmpoly->geoms[j], 0));
-						/* TODO: cleanup all GEOS memory */
-						HANDLE_GEOS_ERROR("Geometry could not be converted to GEOS");
-						PG_RETURN_NULL();
-					geoms[curgeom++] = g;
-				lwmpoly_free(lwmpoly);
-		** Take our GEOS Polygons and turn them into a GEOS MultiPolygon,
-		** then pass that into cascaded union.
-		if (curgeom > 0)
-			g1 = GEOSGeom_createCollection(GEOS_MULTIPOLYGON, geoms, curgeom);
-			if ( ! g1 )
-				/* TODO: cleanup geoms memory */
-				HANDLE_GEOS_ERROR("Could not create MULTIPOLYGON from geometry array");
-				PG_RETURN_NULL();
-			g2 = GEOSUnionCascaded(g1);
-			GEOSGeom_destroy(g1);
-			if ( ! g2 )
-				HANDLE_GEOS_ERROR("GEOSUnionCascaded");
-				PG_RETURN_NULL();
-			GEOSSetSRID(g2, srid);
-			result = GEOS2POSTGIS(g2, is3d);
-			GEOSGeom_destroy(g2);
-		else
-			/* All we found were NULLs, so let's return NULL */
-			PG_RETURN_NULL();
-	else
-		** Heterogeneous result, let's slog through this one union at a time.
-#else
-#endif
-			GSERIALIZED *geom;
-			if ( isnull )
-				continue;
-			geom = (GSERIALIZED *)DatumGetPointer(value);
-			pgis_geom = geom;
-			POSTGIS_DEBUGF(3, "geom %d @ %p", i, geom);
-			/* Check is3d flag */
-			if ( gserialized_has_z(geom) ) is3d = 1;
-			/* Check SRID homogeneity and initialize geos result */
-			if ( ! geos_result )
-				geos_result = (GEOSGeometry *)POSTGIS2GEOS(geom);
-				if ( 0 == geos_result )   /* exception thrown at construction */
-					HANDLE_GEOS_ERROR("geometry could not be converted to GEOS");
-					PG_RETURN_NULL();
-				srid = gserialized_get_srid(geom);
-				POSTGIS_DEBUGF(3, "first geom is a %s", lwtype_name(gserialized_get_type(geom)));
-			else
-				error_if_srid_mismatch(srid, gserialized_get_srid(geom));
-                g1 = POSTGIS2GEOS(pgis_geom);
-                if ( 0 == g1 )   /* exception thrown at construction */
-                    HANDLE_GEOS_ERROR("First argument geometry could not be converted to GEOS");
-                    PG_RETURN_NULL();
-				POSTGIS_DEBUGF(3, "unite_garray(%d): adding geom %d to union (%s)",
-				               call, i, lwtype_name(gserialized_get_type(geom)));
-				g2 = GEOSUnion(g1, geos_result);
-				if ( g2 == NULL )
-					GEOSGeom_destroy((GEOSGeometry *)g1);
-					GEOSGeom_destroy((GEOSGeometry *)geos_result);
-					HANDLE_GEOS_ERROR("GEOSUnion");
-				geos_result = g2;
-		/* If geos_result is set then we found at least one non-NULL geometry */
-		if (geos_result)
-			GEOSSetSRID(geos_result, srid);
-			result = GEOS2POSTGIS(geos_result, is3d);
-			GEOSGeom_destroy(geos_result);
-		else
-			PG_RETURN_NULL();
-	if ( result == NULL )
-		/* Union returned a NULL geometry */
-		PG_RETURN_NULL();
-	PG_RETURN_POINTER(result);
  * @example ST_UnaryUnion {@link #geomunion} SELECT ST_UnaryUnion(
  *      'POLYGON((0 0, 10 0, 0 10, 10 10, 0 0))'
@@ -1186,29 +878,9 @@
-#if POSTGIS_GEOS_VERSION >= 32
 	g3 = GEOSBufferWithStyle(g1, size, quadsegs, endCapStyle, joinStyle, mitreLimit);
-#else /* POSTGIS_GEOS_VERSION < 32 */
-	if ( mitreLimit != DEFAULT_MITRE_LIMIT ||
-	        endCapStyle != DEFAULT_ENDCAP_STYLE ||
-	        joinStyle != DEFAULT_JOIN_STYLE )
-		        "specifying a mitre limit != %d or styles different "
-		        "from 'round' (needs 3.2 or higher)",
-		        DEFAULT_MITRE_LIMIT, POSTGIS_GEOS_VERSION);
-	g3 = GEOSBuffer(g1,size,quadsegs);
 	if (g3 == NULL)
 		HANDLE_GEOS_ERROR("GEOSBuffer");
@@ -1239,15 +911,6 @@
 PG_FUNCTION_INFO_V1(ST_OffsetCurve);
 Datum ST_OffsetCurve(PG_FUNCTION_ARGS)
-	        "ST_OffsetCurve function "
-	        "(needs 3.2 or higher)",
-	PG_RETURN_NULL(); /* never get here */
-#else
 	GSERIALIZED	*gser_input;
 	GSERIALIZED *gser_result;
 	LWGEOM *lwgeom_input;
@@ -1379,8 +1042,6 @@
 	lwgeom_free(lwgeom_input);
 	lwgeom_free(lwgeom_result);
 	PG_RETURN_POINTER(gser_result);
@@ -1694,9 +1355,6 @@
 	LWGEOM *lwgeom;
 	bool result;
 	GEOSGeom g1;
-	GBOX box1;
-#endif
 	geom1 = PG_GETARG_GSERIALIZED_P(0);
@@ -1704,20 +1362,6 @@
 	if ( gserialized_is_empty(geom1) )
 		PG_RETURN_BOOL(true);
-	/* Short circuit and return FALSE if we have infinite coordinates */
-	if ( gserialized_get_gbox_p(geom1, &box1) )
-		if ( isinf(box1.xmax) || isinf(box1.ymax) || isinf(box1.xmin) || isinf(box1.ymin) ||
-		        isnan(box1.xmax) || isnan(box1.ymax) || isnan(box1.xmin) || isnan(box1.ymin)  )
-			lwpgnotice("Geometry contains an Inf or NaN coordinate");
-			PG_RETURN_BOOL(FALSE);
-#endif
 	lwgeom = lwgeom_from_gserialized(geom1);
@@ -1761,31 +1405,9 @@
 	char *reason_str = NULL;
 	text *result = NULL;
 	const GEOSGeometry *g1 = NULL;
-	GBOX box;
-#endif
 	geom = PG_GETARG_GSERIALIZED_P(0);
-	/* Short circuit and return if we have infinite coordinates */
-	if ( gserialized_get_gbox_p(geom, &box) )
-		if ( isinf(box.xmax) || isinf(box.ymax) || isinf(box.xmin) || isinf(box.ymin) ||
-		        isnan(box.xmax) || isnan(box.ymax) || isnan(box.xmin) || isnan(box.ymin)  )
-			const char *rsn = "Geometry contains an Inf or NaN coordinate";
-			size_t len = strlen(rsn);
-			result = palloc(VARHDRSZ + len);
-			SET_VARSIZE(result, VARHDRSZ + len);
-			memcpy(VARDATA(result), rsn, len);
-			PG_FREE_IF_COPY(geom, 0);
-#endif
 	g1 = (GEOSGeometry *)POSTGIS2GEOS(geom);
@@ -1806,10 +1428,8 @@
 		result = cstring2text(lwgeom_geos_errmsg);
@@ -1819,14 +1439,6 @@
 PG_FUNCTION_INFO_V1(isvaliddetail);
 Datum isvaliddetail(PG_FUNCTION_ARGS)
-	        "'isValidDetail' function (3.3.0+ required)",
-	PG_RETURN_NULL();
 	GSERIALIZED *geom = NULL;
 	char *values[3]; /* valid bool, reason text, location geometry */
@@ -1913,8 +1525,6 @@
 	heap_freetuple(tuple);
 	PG_RETURN_HEAPTUPLEHEADER(result);
@@ -2928,9 +2538,7 @@
 	GEOSGeometry *g1, *g2;
 	char *relate_str;
 	text *result;
 	int bnr = GEOSRELATE_BNR_OGC;
-#endif
 	POSTGIS_DEBUG(2, "in relate_full()");
@@ -2941,16 +2549,7 @@
 	if ( PG_NARGS() > 2 )
 		bnr = PG_GETARG_INT32(2);
-#else
-			"specifying a boundary node rule with ST_Relate"
-			" (3.3.0+ required)",
-		PG_RETURN_NULL();
-#endif
 	errorIfGeometryCollection(geom1,geom2);
@@ -2980,11 +2579,7 @@
 	POSTGIS_DEBUGF(3, "%s", GEOSGeomToWKT(g1));
 	POSTGIS_DEBUGF(3, "%s", GEOSGeomToWKT(g2));
 	relate_str = GEOSRelateBoundaryNodeRule(g1, g2, bnr);
-#else
-	relate_str = GEOSRelate(g1, g2);
-#endif
@@ -3682,13 +3277,6 @@
 PG_FUNCTION_INFO_V1(ST_Snap);
 Datum ST_Snap(PG_FUNCTION_ARGS)
-	        "'ST_Snap' function (3.3.0+ required)",
-	PG_RETURN_NULL();
 	GSERIALIZED *geom1, *geom2, *result;
 	LWGEOM *lwgeom1, *lwgeom2, *lwresult;
 	double tolerance;
@@ -3710,9 +3298,6 @@
 	lwgeom_free(lwresult);
@@ -3792,13 +3377,6 @@
 PG_FUNCTION_INFO_V1(ST_SharedPaths);
 Datum ST_SharedPaths(PG_FUNCTION_ARGS)
-	        "'ST_SharedPaths' function (3.3.0+ required)",
-	PG_RETURN_NULL();
 	GSERIALIZED *geom1, *geom2, *out;
 	LWGEOM *g1, *g2, *lwgeom_out;
@@ -3825,9 +3403,6 @@
 	PG_FREE_IF_COPY(geom1, 0);
 	PG_RETURN_POINTER(out);
@@ -3843,13 +3418,6 @@
 PG_FUNCTION_INFO_V1(ST_Node);
 Datum ST_Node(PG_FUNCTION_ARGS)
-	        "'ST_Node' function (3.3.0+ required)",
-	PG_RETURN_NULL();
 	GSERIALIZED *geom1, *out;
 	LWGEOM *g1, *lwgeom_out;
@@ -3871,8 +3439,5 @@
Modified: trunk/postgis/lwgeom_geos_clean.c
--- trunk/postgis/lwgeom_geos_clean.c	2015-12-01 10:52:02 UTC (rev 14465)
+++ trunk/postgis/lwgeom_geos_clean.c	2015-12-01 23:16:41 UTC (rev 14466)
@@ -52,11 +52,6 @@
 PG_FUNCTION_INFO_V1(ST_MakeValid);
 Datum ST_MakeValid(PG_FUNCTION_ARGS)
-	elog(ERROR, "You need GEOS-3.3.0 or up for ST_MakeValid");
-	PG_RETURN_NULL();
 	GSERIALIZED *in, *out;
 	LWGEOM *lwgeom_in, *lwgeom_out;
@@ -91,11 +86,8 @@
 	out = geometry_serialize(lwgeom_out);
 /* Uses GEOS internally */
 static LWGEOM* lwgeom_clean(LWGEOM* lwgeom_in);
 static LWGEOM*
@@ -138,18 +130,11 @@
 	return lwgeom_out;
 Datum ST_CleanGeometry(PG_FUNCTION_ARGS);
 PG_FUNCTION_INFO_V1(ST_CleanGeometry);
-	elog(ERROR, "You need GEOS-3.3.0 or up for ST_CleanGeometry");
-	PG_RETURN_NULL();
@@ -175,7 +160,5 @@
Modified: trunk/postgis/lwgeom_geos_relatematch.c
--- trunk/postgis/lwgeom_geos_relatematch.c	2015-12-01 10:52:02 UTC (rev 14465)
+++ trunk/postgis/lwgeom_geos_relatematch.c	2015-12-01 23:16:41 UTC (rev 14466)
@@ -40,14 +40,6 @@
 PG_FUNCTION_INFO_V1(ST_RelateMatch);
 Datum ST_RelateMatch(PG_FUNCTION_ARGS)
-	lwpgerror("The GEOS version this postgis binary "
-	        "'ST_RelateMatch' function (3.3.0+ required)",
-	PG_RETURN_NULL();
 	char *mat, *pat;
 	text *mat_text, *pat_text;
 	int result;
@@ -72,8 +64,5 @@
 	lwfree(mat); lwfree(pat);
 	PG_RETURN_BOOL(result);
Modified: trunk/raster/rt_core/rt_geometry.c
--- trunk/raster/rt_core/rt_geometry.c	2015-12-01 10:52:02 UTC (rev 14465)
+++ trunk/raster/rt_core/rt_geometry.c	2015-12-01 23:16:41 UTC (rev 14466)
@@ -470,18 +470,10 @@
 		rtdealloc(gv);
 		/* create geometry collection */
 		gc = GEOSGeom_createCollection(GEOS_GEOMETRYCOLLECTION, geoms, geomscount);
-#else
-		gc = GEOSGeom_createCollection(GEOS_MULTIPOLYGON, geoms, geomscount);
-#endif
 		if (gc == NULL) {
 			rterror("rt_raster_surface: Could not create GEOS GEOMETRYCOLLECTION from set of pixel polygons");
-#else
-			rterror("rt_raster_surface: Could not create GEOS MULTIPOLYGON from set of pixel polygons");
-#endif
 			for (i = 0; i < geomscount; i++)
 				GEOSGeom_destroy(geoms[i]);
@@ -490,20 +482,13 @@
 		/* run the union */
 		gunion = GEOSUnaryUnion(gc);
-#else
-		gunion = GEOSUnionCascaded(gc);
-#endif
 		GEOSGeom_destroy(gc);
 		rtdealloc(geoms);
 		if (gunion == NULL) {
 			rterror("rt_raster_surface: Could not union the pixel polygons using GEOSUnaryUnion()");
-#else
-			rterror("rt_raster_surface: Could not union the pixel polygons using GEOSUnionCascaded()");
-#endif
 			return ES_ERROR;
@@ -517,10 +502,6 @@
 		do {
 			LWGEOM *mpolyValid = NULL;
-			break;
-#endif
 			if (GEOSisValid(gunion))
 				break;
@@ -1253,11 +1234,6 @@
 			if not, try to make valid
 		do {
-			/* nothing can be done if the geometry was invalid if GEOS < 3.3 */
-			break;
-#endif
 			ggeom = (GEOSGeometry *) LWGEOM2GEOS(lwgeom, 0);
 			if (ggeom == NULL) {
 				rtwarn("Cannot test geometry for validity");
Modified: trunk/raster/test/cunit/cu_raster_geometry.c
--- trunk/raster/test/cunit/cu_raster_geometry.c	2015-12-01 10:52:02 UTC (rev 14465)
+++ trunk/raster/test/cunit/cu_raster_geometry.c	2015-12-01 23:16:41 UTC (rev 14466)
@@ -317,11 +317,9 @@
 	CU_ASSERT_EQUAL(err, ES_NONE);
 	CU_ASSERT(mpoly != NULL);
 	wkt = lwgeom_to_text(lwmpoly_as_lwgeom(mpoly));
 	CU_ASSERT_STRING_EQUAL(wkt, "MULTIPOLYGON(((1 -1,1 0,5 0,5 -5,4 -5,0 -5,0 -1,1 -1),(1 -1,1 -2,2 -2,2 -1,1 -1),(2 -2,2 -3,3 -3,3 -2,2 -2)))");
-#else
-	CU_ASSERT_STRING_EQUAL(wkt, "MULTIPOLYGON(((1 0,1 -1,0 -1,0 -5,4 -5,5 -5,5 0,1 0),(1 -1,1 -2,2 -2,2 -3,3 -3,3 -2,2 -2,2 -1,1 -1)))");
-#endif
 	rtdealloc(wkt);
 	lwmpoly_free(mpoly);
 	mpoly = NULL;
@@ -333,11 +331,9 @@
 	CU_ASSERT_STRING_EQUAL(wkt, "MULTIPOLYGON(((1 -1,1 0,5 0,5 -5,4 -5,0 -5,0 -1,1 -1),(1 -1,1 -2,2 -2,2 -1,1 -1),(2 -2,2 -3,3 -3,3 -2,2 -2),(3 -3,3 -4,4 -4,4 -3,3 -3)))");
-#else
-	CU_ASSERT_STRING_EQUAL(wkt, "MULTIPOLYGON(((1 0,1 -1,0 -1,0 -5,4 -5,5 -5,5 0,1 0),(1 -1,1 -2,2 -2,2 -3,3 -3,3 -4,4 -4,4 -3,3 -3,3 -2,2 -2,2 -1,1 -1)))");
-#endif
 	rtdealloc(wkt);
 	mpoly = NULL;
