[postgis-tickets] r14467 - #2259, ST_Voronoi
    Daniel Baston
    dbaston at gmail.com
    Tue Dec  1 17:10:34 PST 2015
Author: dbaston
Date: 2015-12-01 17:10:33 -0800 (Tue, 01 Dec 2015)
New Revision: 14467
Added:
   trunk/regress/voronoi.sql
   trunk/regress/voronoi_expected
   trunk/doc/reference_processing.xml
   trunk/liblwgeom/cunit/cu_triangulate.c
   trunk/liblwgeom/liblwgeom.h.in
   trunk/liblwgeom/lwgeom_geos.c
   trunk/postgis/lwgeom_geos.c
   trunk/postgis/postgis.sql.in
   trunk/regress/Makefile.in
#2259, ST_Voronoi
Modified: trunk/doc/reference_processing.xml
--- trunk/doc/reference_processing.xml	2015-12-01 23:16:41 UTC (rev 14466)
+++ trunk/doc/reference_processing.xml	2015-12-02 01:10:33 UTC (rev 14467)
@@ -3577,4 +3577,76 @@
 		</para>
 	  </refsection>
 	</refentry>
+	<refentry id="ST_Voronoi">
+	  <refnamediv>
+		<refname>ST_Voronoi</refname>
+		<refpurpose>Computes a Voronoi diagram from the vertices of a geometry.</refpurpose>
+	  </refnamediv>
+	  <refsynopsisdiv>
+		<funcsynopsis>
+		  <funcprototype>
+			<funcdef>geometry <function>ST_Voronoi</function></funcdef>
+			<paramdef>
+				<parameter>g1</parameter>
+				<type>geometry</type>
+			</paramdef>
+			<paramdef choice="opt">
+				<parameter>clip</parameter>
+			</paramdef>
+				<parameter>tolerance</parameter>
+				<type>float8</type>
+			</paramdef>
+				<parameter>return_polygons</parameter>
+				<type>boolean</type>
+			</paramdef>
+		  </funcprototype>
+		</funcsynopsis>
+	  </refsynopsisdiv>
+	  <refsection>
+		<title>Description</title>
+		<para>
+			ST_Voronoi computes a two-dimensional Voronoi diagram from the vertices of
+			the supplied geometry.  By default, the result will be a GeometryCollection of
+			Polygons that covers an envelope larger than the extent of the input vertices.
+		</para>
+		<para>
+			Optional parameters:
+		<itemizedlist>
+			<listitem>
+				<para>'clip' : If a geometry is supplied as the "clip" parameter, the diagram will be extended to cover the
+					envelope of the "clip" geometry, unless that envelope is smaller than the default envelope.
+					(default = NULL)</para>
+			</listitem>
+			<listitem>
+			<para>'tolerance' : The distance within which vertices will be considered equivalent.  Robustness of the algorithm can be improved by supplying a nonzero tolerance distance.  (default = 0.0)</para>
+			</listitem>
+			<listitem>
+			<para>'return_polygons' : if true, the result of ST_Voronoi will be a GeometryCollection of Polygons.  If false, the result will be a MultiLineString. (default = true)</para>
+			</listitem>
+		</itemizedlist>
+		</para>
+		<para>Availability: 2.3.0 - requires GEOS >= 3.5.0.</para>
+	  </refsection>
+	  <!-- Optionally add a "See Also" section -->
+	  <refsection>
+		<title>See Also</title>
+		<para>
+			<xref linkend="ST_DelaunayTriangles" />,
+			<xref linkend="ST_Collect" />
+		</para>
+	  </refsection>
+	</refentry>
 </sect1>
Modified: trunk/liblwgeom/cunit/cu_triangulate.c
--- trunk/liblwgeom/cunit/cu_triangulate.c	2015-12-01 23:16:41 UTC (rev 14466)
+++ trunk/liblwgeom/cunit/cu_triangulate.c	2015-12-02 01:10:33 UTC (rev 14467)
@@ -3,6 +3,7 @@
  * PostGIS - Spatial Types for PostgreSQL
  * http://postgis.net
+ * Copyright (C) 2015 Daniel Baston <dbaston at gmail.com>
  * Copyright (C) 2012 Sandro Santilli <strk at keybit.net>
  * This is free software; you can redistribute and/or modify it under
@@ -13,7 +14,6 @@
 #include "CUnit/Basic.h"
 #include "cu_tester.h"
-#include "liblwgeom.h"
 #include "liblwgeom_internal.h"
 static void test_lwgeom_delaunay_triangulation(void)
@@ -43,10 +43,70 @@
 	CU_ASSERT_STRING_EQUAL(wkt, exp_wkt);
 	lwfree(wkt);
-#endif /* POSTGIS_GEOS_VERSION >= 33 */
+#endif /* POSTGIS_GEOS_VERSION >= 34 */
+static void test_lwgeom_voronoi_diagram(void)
+#if POSTGIS_GEOS_VERSION >= 35
+	LWGEOM* in = lwgeom_from_wkt("MULTIPOINT(4 4, 5 5, 6 6)", LW_PARSER_CHECK_NONE);
+	LWGEOM* out_boundaries = lwgeom_voronoi_diagram(in, NULL, 0, 0);
+	LWGEOM* out_lines = lwgeom_voronoi_diagram(in, NULL, 0, 1);
+	/* For boundaries we get a generic LWCOLLECTION */
+	CU_ASSERT_EQUAL(COLLECTIONTYPE, lwgeom_get_type(out_boundaries));
+	/* For lines we get a MULTILINETYPE */
+	CU_ASSERT_EQUAL(MULTILINETYPE,  lwgeom_get_type(out_lines));
+	lwgeom_free(in);
+	lwgeom_free(out_boundaries);
+	lwgeom_free(out_lines);
+#endif /* POSTGIS_GEOS_VERSION >= 35 */
+static void test_lwgeom_voronoi_diagram_custom_envelope(void)
+	LWGEOM* for_extent = lwgeom_from_wkt("LINESTRING (-10 -10, 10 10)", LW_PARSER_CHECK_NONE);
+	const GBOX* clipping_extent = lwgeom_get_bbox(for_extent);
+	LWGEOM* out = lwgeom_voronoi_diagram(in, clipping_extent, 0, 0);
+	const GBOX* output_extent = lwgeom_get_bbox(out);
+	CU_ASSERT_TRUE(gbox_same(clipping_extent, output_extent));
+	lwgeom_free(in);
+	lwgeom_free(for_extent);
+	lwgeom_free(out);
+static void assert_empty_diagram(char* wkt, double tolerance)
+	LWGEOM* in = lwgeom_from_wkt(wkt, LW_PARSER_CHECK_NONE);
+	LWGEOM* out = lwgeom_voronoi_diagram(in, NULL, 0, 0);
+	CU_ASSERT_TRUE(lwgeom_is_collection(out));
+	CU_ASSERT_EQUAL(COLLECTIONTYPE, lwgeom_get_type(out));
+	lwgeom_free(in);
+	lwgeom_free(out);
+static void test_lwgeom_voronoi_diagram_expected_empty(void)
+	assert_empty_diagram("POLYGON EMPTY", 0);
+	assert_empty_diagram("POINT (1 2)", 0);
+	/* This one produces an empty diagram because our two unqiue points
+	 * collapse onto one after considering the tolerance. */
+	assert_empty_diagram("MULTIPOINT (0 0, 0 0.00001)", 0.001);
 ** Used by test harness to register the tests in this file.
@@ -55,4 +115,7 @@
 	CU_pSuite suite = CU_add_suite("triangulate", NULL, NULL);
 	PG_ADD_TEST(suite, test_lwgeom_delaunay_triangulation);
+	PG_ADD_TEST(suite, test_lwgeom_voronoi_diagram);
+	PG_ADD_TEST(suite, test_lwgeom_voronoi_diagram_expected_empty);
+	PG_ADD_TEST(suite, test_lwgeom_voronoi_diagram_custom_envelope);
Modified: trunk/liblwgeom/liblwgeom.h.in
--- trunk/liblwgeom/liblwgeom.h.in	2015-12-01 23:16:41 UTC (rev 14466)
+++ trunk/liblwgeom/liblwgeom.h.in	2015-12-02 01:10:33 UTC (rev 14467)
@@ -2238,11 +2238,24 @@
  * triangulation on them.
  * @param geom the input geometry
- * @param tolerance an optional snapping tolerance for improved tolerance
+ * @param tolerance an optional snapping tolerance for improved robustness
  * @param edgeOnly if non-zero the result will be a MULTILINESTRING,
  *                 otherwise it'll be a COLLECTION of polygons.
 LWGEOM* lwgeom_delaunay_triangulation(const LWGEOM *geom, double tolerance, int edgeOnly);
+ * Take vertices of a geometry and build the Voronoi diagram
+ * @param g the input geometry
+ * @param env an optional envelope for clipping the results
+ * @param output_edges if non-zero the result will be a MULTILINESTRING,
+ *                 otherwise it'll be a COLLECTION of polygons.
+ * Requires GEOS-3.5.0 or higher
+LWGEOM* lwgeom_voronoi_diagram(const LWGEOM* g, const GBOX* env, double tolerance, int output_edges);
 #endif /* !defined _LIBLWGEOM_H  */
Modified: trunk/liblwgeom/lwgeom_geos.c
--- trunk/liblwgeom/lwgeom_geos.c	2015-12-01 23:16:41 UTC (rev 14466)
+++ trunk/liblwgeom/lwgeom_geos.c	2015-12-02 01:10:33 UTC (rev 14467)
@@ -1657,3 +1657,101 @@
 #endif /* POSTGIS_GEOS_VERSION < 34 */
+static
+GEOSCoordSequence* lwgeom_get_geos_coordseq_2d(const LWGEOM* g, uint32_t num_points)
+	uint32_t i = 0;
+	uint8_t num_dims = 2;
+	LWPOINTITERATOR* it;
+	GEOSCoordSequence* coords;
+	POINT4D tmp;
+	coords = GEOSCoordSeq_create(num_points, num_dims);
+	if (!coords)
+		return NULL;
+	it = lwpointiterator_create(g);
+	while(lwpointiterator_next(it, &tmp))
+		if(i >= num_points)
+			lwerror("Incorrect num_points provided to lwgeom_get_geos_coordseq_2d");
+			GEOSCoordSeq_destroy(coords);
+			lwpointiterator_destroy(it);
+			return NULL;
+		if(!GEOSCoordSeq_setX(coords, i, tmp.x) || !GEOSCoordSeq_setY(coords, i, tmp.y))
+			return NULL;
+		i++;
+	return coords;
+LWGEOM* lwgeom_voronoi_diagram(const LWGEOM* g, const GBOX* env, double tolerance, int output_edges) {
+#if POSTGIS_GEOS_VERSION < 35
+	lwerror("lwgeom_voronoi_diagram: GEOS 3.5 or higher required");
+	return NULL;
+#else
+	uint32_t num_points = lwgeom_count_vertices(g);
+	LWGEOM *lwgeom_result;
+	char is_3d = LW_FALSE;
+	int srid = lwgeom_get_srid(g);
+	GEOSGeometry* geos_geom;
+	GEOSGeometry* geos_env = NULL;
+	GEOSGeometry* geos_result;
+	if (num_points < 2)
+		LWCOLLECTION* empty = lwcollection_construct_empty(COLLECTIONTYPE, lwgeom_get_srid(g), 0, 0);
+		return lwcollection_as_lwgeom(empty);
+	initGEOS(lwnotice, lwgeom_geos_error);
+	/* Instead of using the standard LWGEOM2GEOS transformer, we read the vertices of the
+	 * LWGEOM directly and put them into a single GEOS CoordinateSeq that can be used to
+	 * define a LineString.  This allows us to process geometry types that may not be
+	 * supported by GEOS, and reduces the memory requirements in cases of many geometries
+	 * with few points (such as LWMPOINT).
+	coords = lwgeom_get_geos_coordseq_2d(g, num_points);
+	if (!coords)
+		return NULL;
+	geos_geom = GEOSGeom_createLineString(coords);
+	if (!geos_geom)
+		return NULL;
+	if (env)
+		geos_env = GBOX2GEOS(env);
+	geos_result = GEOSVoronoiDiagram(geos_geom, geos_env, tolerance, output_edges);
+	GEOSGeom_destroy(geos_geom);
+	if (env)
+		GEOSGeom_destroy(geos_env);
+	if (!geos_result)
+		return NULL;
+	lwgeom_result = GEOS2LWGEOM(geos_result, is_3d);
+	GEOSGeom_destroy(geos_result);
+	lwgeom_set_srid(lwgeom_result, srid);
+	return lwgeom_result;
+#endif /* POSTGIS_GEOS_VERSION < 35 */
Modified: trunk/postgis/lwgeom_geos.c
--- trunk/postgis/lwgeom_geos.c	2015-12-01 23:16:41 UTC (rev 14466)
+++ trunk/postgis/lwgeom_geos.c	2015-12-02 01:10:33 UTC (rev 14467)
@@ -3441,3 +3441,102 @@
 	PG_RETURN_POINTER(out);
+ * ST_Voronoi
+ * Returns a Voronoi diagram constructed
+ * from the points of the input geometry.
+Datum ST_Voronoi(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(ST_Voronoi);
+	lwpgerror("The GEOS version this PostGIS binary "
+	        "was compiled against (%d) doesn't support "
+	        "'ST_Voronoi' function (3.5.0+ required)",
+	        POSTGIS_GEOS_VERSION);
+	PG_RETURN_NULL();
+#else /* POSTGIS_GEOS_VERSION >= 35 */
+	GSERIALIZED* input;
+	GSERIALIZED* clip;
+	GSERIALIZED* result;
+	LWGEOM* lwgeom_input;
+	LWGEOM* lwgeom_result;
+	double tolerance;
+	GBOX clip_envelope;
+	int custom_clip_envelope;
+	int return_polygons;
+	/* Return NULL on NULL geometry */
+	if (PG_ARGISNULL(0))
+		PG_RETURN_NULL();
+	/* Read our tolerance value */
+	if (PG_ARGISNULL(2))
+		lwpgerror("Tolerance must be a positive number.");
+		PG_RETURN_NULL();
+	tolerance = PG_GETARG_FLOAT8(2);
+	if (tolerance < 0)
+		PG_RETURN_NULL();
+	/* Are we returning lines or polygons? */
+	if (PG_ARGISNULL(3))
+		lwpgerror("return_polygons must be true or false.");
+		PG_RETURN_NULL();
+	return_polygons = PG_GETARG_BOOL(3);
+	/* Read our clipping envelope, if applicable. */
+	custom_clip_envelope = !PG_ARGISNULL(1);
+	if (custom_clip_envelope) {
+		clip = PG_GETARG_GSERIALIZED_P(1);
+		if (!gserialized_get_gbox_p(clip, &clip_envelope))
+			lwpgerror("Could not determine envelope of clipping geometry.");
+			PG_FREE_IF_COPY(clip, 0);
+			PG_RETURN_NULL();
+	/* Read our input geometry */
+	input = PG_GETARG_GSERIALIZED_P(0);
+	lwgeom_input = lwgeom_from_gserialized(input);
+	if(!lwgeom_input)
+		lwpgerror("Could not read input geometry.");
+		PG_FREE_IF_COPY(input, 0);
+		PG_RETURN_NULL();
+	lwgeom_result = lwgeom_voronoi_diagram(lwgeom_input, custom_clip_envelope ? &clip_envelope : NULL, tolerance, !return_polygons);
+	lwgeom_free(lwgeom_input);
+	if (!lwgeom_result)
+		lwpgerror("Error computing Voronoi diagram.");
+		PG_RETURN_NULL();
+	result = geometry_serialize(lwgeom_result);
+	lwgeom_free(lwgeom_result);
+	PG_RETURN_POINTER(result);
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in	2015-12-01 23:16:41 UTC (rev 14466)
+++ trunk/postgis/postgis.sql.in	2015-12-02 01:10:33 UTC (rev 14467)
@@ -3516,7 +3516,37 @@
        LANGUAGE 'c' IMMUTABLE STRICT
        COST 100;
+-- ST_Voronoi
+-- ST_Voronoi(g1 geometry, clip geometry, tolerance float8, return_polygons boolean)
+-- Builds a Voronoi Diagram from the vertices of the supplied geometry.
+-- By default, the diagram will be extended to an envelope larger than the
+-- input points.
+-- If a second geometry is supplied, the diagram will be extended to fill the
+-- envelope of the second geometry, unless that is smaller than the default
+-- envelope.
+-- If a tolerance is given it will be used to snap the input points
+-- each-other.
+-- If return_polygons is true, returns a GeometryCollection of polygons.
+-- If return_polygons is false, returns a MultiLineString.
+-- Availability: 2.3.0
+-- Requires GEOS >= 3.5.0
+CREATE OR REPLACE FUNCTION ST_Voronoi(g1 geometry, clip geometry DEFAULT NULL, tolerance float8 DEFAULT 0.0, return_polygons boolean DEFAULT true)
+       RETURNS geometry
+       AS 'MODULE_PATHNAME', 'ST_Voronoi'
+       LANGUAGE 'c' IMMUTABLE
+       COST 100;
 -- Aggregates and their supporting functions
Modified: trunk/regress/Makefile.in
--- trunk/regress/Makefile.in	2015-12-01 23:16:41 UTC (rev 14466)
+++ trunk/regress/Makefile.in	2015-12-02 01:10:33 UTC (rev 14467)
@@ -207,10 +207,11 @@
 ifeq ($(shell expr $(POSTGIS_GEOS_VERSION) ">=" 35),1)
 	# GEOS-3.5 adds:
-	# ST_ClipByBox2d
+	# ST_ClipByBox2d, ST_Subdivide, ST_Voronoi
 	TESTS += \
 		clipbybox2d \
-		subdivide
+		subdivide \
+		voronoi
 endif
Added: trunk/regress/voronoi.sql
--- trunk/regress/voronoi.sql	                        (rev 0)
+++ trunk/regress/voronoi.sql	2015-12-02 01:10:33 UTC (rev 14467)
@@ -0,0 +1,17 @@
+-- postgres
+-- SRID is preserved
+SELECT 1,  32145 = ST_SRID(ST_Voronoi('SRID=32145;MULTIPOINT (0 0, 1 1, 2 2)'));
+-- NULL -> NULL
+SELECT 2,  ST_Voronoi(NULL) IS NULL;
+-- NULL tolerance produces error
+SELECT 3,  ST_Voronoi('MULTIPOINT (0 0, 1 1, 2 2)', NULL, NULL);
+-- NULL return_polygons produces error
+SELECT 4,  ST_Voronoi('MULTIPOINT (0 0, 1 1, 2 2)', NULL, 0, NULL);
+-- Tolerance can't be negative
+SELECT 5,  ST_Voronoi('MULTIPOINT (0 0, 1 1, 2 2)', NULL, -2);
+-- Output types are correct
+SELECT 6,  GeometryType(ST_Voronoi('MULTIPOINT (0 0, 1 1, 2 2)')) = 'GEOMETRYCOLLECTION';
+SELECT 7,  GeometryType(ST_Voronoi('MULTIPOINT (0 0, 1 1, 2 2)', NULL, 0, false)) = 'MULTILINESTRING';
+-- Clipping extent is handled correctly
+SELECT 8,  ST_Equals(ST_Envelope('LINESTRING (-20 -10, 10 10)'::geometry), ST_Envelope(ST_Voronoi('MULTIPOINT (0 0, 1 1, 2 2)', 'MULTIPOINT (-20 -10, 10 10)')));
Added: trunk/regress/voronoi_expected
--- trunk/regress/voronoi_expected	                        (rev 0)
+++ trunk/regress/voronoi_expected	2015-12-02 01:10:33 UTC (rev 14467)
@@ -0,0 +1,8 @@
+1|t
+2|t
+ERROR:  Tolerance must be a positive number.
+ERROR:  return_polygons must be true or false.
+6|t
+7|t
+8|t
