[postgis-tickets] [PostGIS] #3382: Avoid deserializing small geometries during index operations
PostGIS trac at osgeo.org
Wed Dec 2 15:53:51 PST 2015
  Reporter:  dbaston      |      Owner:  pramsey
      Type:  enhancement  |     Status:  new
  Priority:  high         |  Milestone:  PostGIS 2.3.0
 Component:  postgis      |    Version:  trunk
Resolution:               |   Keywords:
Comment (by dbaston):
 Updated the PR with an some cunit tests and an additional bugfix for
 gserialized_peek_gbox_p.  I can pull that stuff out into a separate
 ticket/patch if that's preferable.
 History in the PR is cluttered by a merge (there has to be a better way),
 but you can see the actual changes proposed at
 https://github.com/postgis/postgis/compare/svn-trunk...dbaston:trac-3382
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3382#comment:3>
