[postgis-tickets] r14478 - #3382, avoid deserializing small geometries during index ops
Daniel Baston dbaston at gmail.com
Mon Dec 7 14:12:31 PST 2015
Author: dbaston
Date: 2015-12-07 14:12:31 -0800 (Mon, 07 Dec 2015)
New Revision: 14478
   trunk/liblwgeom/cunit/cu_libgeom.c
   trunk/liblwgeom/g_serialized.c
   trunk/postgis/gserialized_gist_2d.c
Modified: trunk/liblwgeom/cunit/cu_libgeom.c
--- trunk/liblwgeom/cunit/cu_libgeom.c	2015-12-04 00:11:26 UTC (rev 14477)
+++ trunk/liblwgeom/cunit/cu_libgeom.c	2015-12-07 22:12:31 UTC (rev 14478)
@@ -15,6 +15,7 @@
 #include "CUnit/Basic.h"
 #include "liblwgeom_internal.h"
+#include "g_serialized.c" /* for gserialized_peek_gbox_p */
 #include "cu_tester.h"
 static void test_typmod_macros(void)
@@ -1072,6 +1073,121 @@
     lwfree(s3);
+void test_gserialized_peek_gbox_p_no_box_when_empty(void);
+	uint32_t i;
+	char *ewkt[] =
+		"POINT EMPTY",
+		"LINESTRING EMPTY",
+		"MULTIPOINT EMPTY",
+		"MULTIPOINT (EMPTY)",
+		"MULTILINESTRING EMPTY",
+		"MULTILINESTRING (EMPTY)"
+	for ( i = 0; i < (sizeof ewkt/sizeof(char*)); i++ )
+		LWGEOM* geom = lwgeom_from_wkt(ewkt[i], LW_PARSER_CHECK_NONE);
+		GBOX box;
+		gbox_init(&box);
+		GSERIALIZED* gser = gserialized_from_lwgeom(geom, NULL);
+		CU_ASSERT_FALSE(gserialized_has_bbox(gser));
+		CU_ASSERT_EQUAL(LW_FAILURE, gserialized_peek_gbox_p(gser, &box));
+		lwgeom_free(geom);
+		lwfree(gser);
+void test_gserialized_peek_gbox_p_gets_correct_box(void);
+	uint32_t i;
+	char *ewkt[] =
+		"POINT (2.2945672355 48.85822923236)",
+		"POINTZ (2.2945672355 48.85822923236 15)",
+		"POINTM (2.2945672355 48.85822923236 12)",
+		"POINT ZM (2.2945672355 48.85822923236 12 2)",
+		"MULTIPOINT ((-76.45402132523 44.225406213532))",
+		"MULTIPOINT Z ((-76.45402132523 44.225406213532 112))",
+		"MULTIPOINT ZM ((-76.45402132523 44.225406213532 112 44))",
+		"LINESTRING (2.2945672355 48.85822923236, -76.45402132523 44.225406213532)",
+		"LINESTRING Z (2.2945672355 48.85822923236 6, -76.45402132523 44.225406213532 8)",
+		"LINESTRING ZM (2.2945672355 48.85822923236 3 2, -76.45402132523 44.225406213532 9 4)",
+		"MULTILINESTRING ((2.2945672355 48.85822923236, -76.45402132523 44.225406213532))",
+		"MULTILINESTRING Z ((2.2945672355 48.85822923236 4, -76.45402132523 44.225406213532 3))"
+		GBOX box_from_peek;
+		GBOX box_from_lwgeom;
+		gbox_init(&box_from_peek);
+		gbox_init(&box_from_lwgeom);
+		lwgeom_calculate_gbox(geom, &box_from_lwgeom);
+		gserialized_peek_gbox_p(gser, &box_from_peek);
+		gbox_float_round(&box_from_lwgeom);
+		CU_ASSERT_TRUE(gbox_same(&box_from_peek, &box_from_lwgeom));
+		lwfree(gser);
+void test_gserialized_peek_gbox_p_fails_for_unsupported_cases(void);
+	uint32_t i;
+	char *ewkt[] =
+		"MULTIPOINT ((-76.45402132523 44.225406213532), (-72 33))",
+		"LINESTRING (2.2945672355 48.85822923236, -76.45402132523 44.225406213532, -72 33)",
+		"MULTILINESTRING ((2.2945672355 48.85822923236, -76.45402132523 44.225406213532, -72 33))",
+		"MULTILINESTRING ((2.2945672355 48.85822923236, -76.45402132523 44.225406213532), (-72 33, -71 32))"
+		GBOX box;
+		gbox_init(&box);
+		lwgeom_drop_bbox(geom);
+		/* Construct a GSERIALIZED* that doesn't have a box, so that we can test the
+		 * actual logic of the peek function */
+		size_t expected_size = gserialized_from_lwgeom_size(geom);
+		GSERIALIZED* gser = lwalloc(expected_size);
+		uint8_t* ptr = (uint8_t*) gser;
+		ptr += 8; // Skip header
+		gserialized_from_lwgeom_any(geom, ptr);
+		gser->flags = geom->flags;
+		lwfree(gser);
 ** Used by test harness to register the tests in this file.
@@ -1101,5 +1217,8 @@
 	PG_ADD_TEST(suite, test_lwgeom_as_curve);
 	PG_ADD_TEST(suite, test_lwgeom_scale);
 	PG_ADD_TEST(suite, test_gserialized_is_empty);
-    PG_ADD_TEST(suite, test_gbox_same_2d);
+	PG_ADD_TEST(suite, test_gserialized_peek_gbox_p_no_box_when_empty);
+	PG_ADD_TEST(suite, test_gserialized_peek_gbox_p_gets_correct_box);
+	PG_ADD_TEST(suite, test_gserialized_peek_gbox_p_fails_for_unsupported_cases);
+	PG_ADD_TEST(suite, test_gbox_same_2d);
Modified: trunk/liblwgeom/g_serialized.c
--- trunk/liblwgeom/g_serialized.c	2015-12-04 00:11:26 UTC (rev 14477)
+++ trunk/liblwgeom/g_serialized.c	2015-12-07 22:12:31 UTC (rev 14478)
@@ -227,6 +227,7 @@
 		gbox->xmin = gbox->xmax = dptr[i++];
 		gbox->ymin = gbox->ymax = dptr[i++];
+		gbox->flags = g->flags;
 		if ( FLAGS_GET_Z(g->flags) )
 			gbox->zmin = gbox->zmax = dptr[i++];
@@ -262,6 +263,7 @@
 		gbox->ymin = FP_MIN(dptr[i], dptr[i+ndims]);
 		gbox->ymax = FP_MAX(dptr[i], dptr[i+ndims]);
 			/* Advance to Z */
@@ -286,19 +288,29 @@
 		double *dptr = (double*)(g->data);
 		int *iptr = (int*)(g->data);
 		int ngeoms = iptr[1]; /* Read the ngeoms */
+		int npoints;
 		/* This only works with single-entry multipoints */
 		if ( ngeoms != 1 )
 			return LW_FAILURE;
+		/* Npoints is at <multipointtype><ngeoms><pointtype><npoints> */
+		npoints = iptr[3];
+		/* The check below is necessary because we can have a MULTIPOINT
+		 * that contains a single, empty POINT (ngeoms = 1, npoints = 0) */
+		if ( npoints != 1 )
+			return LW_FAILURE;
 		/* Move forward two doubles (four ints) */
 		/* Past <multipointtype><ngeoms> */
-		/* Past <pointtype><emtpyflat> */
+		/* Past <pointtype><npoints> */
 		i += 2;
 		/* Read the doubles from the one point */
@@ -319,7 +331,7 @@
 		int npoints;
 		/* This only works with 1-line multilines */
 		if ( ngeoms != 1 )
 			return LW_FAILURE;
@@ -343,6 +355,7 @@
 			/* Advance to Z */
Modified: trunk/postgis/gserialized_gist_2d.c
--- trunk/postgis/gserialized_gist_2d.c	2015-12-04 00:11:26 UTC (rev 14477)
+++ trunk/postgis/gserialized_gist_2d.c	2015-12-07 22:12:31 UTC (rev 14478)
@@ -565,17 +565,17 @@
 		/* No, we need to calculate it from the full object. */
 		GBOX gbox;
 		GSERIALIZED *g = (GSERIALIZED*)PG_DETOAST_DATUM(gsdatum);
-		LWGEOM *lwgeom = lwgeom_from_gserialized(g);
-		if ( lwgeom_calculate_gbox(lwgeom, &gbox) == LW_FAILURE )
+		gbox_init(&gbox);
+		if (gserialized_get_gbox_p(g, &gbox) == LW_FAILURE)
 			POSTGIS_DEBUG(4, "could not calculate bbox, returning failure");
-			lwgeom_free(lwgeom);
 			return LW_FAILURE;
 		result = box2df_from_gbox_p(&gbox, box2df);
 	if ( result == LW_SUCCESS )
 		POSTGIS_DEBUGF(4, "got box2df %s", box2df_to_string(box2df));
