[postgis-tickets] [PostGIS] #3393: ST_Area NaN on some polygons
PostGIS trac at osgeo.org
Fri Dec 11 09:21:01 PST 2015
  Reporter:  rfc2616  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.2.1
 Component:  postgis  |    Version:  2.2.x
Resolution:           |   Keywords:
Comment (by pramsey):
 Any reason you're calculating on the sphere in particular? (Not that it
 matters, the old version would be sphere only anyways, probably.) The
 results even when you don't get NaN are pretty bad, even back when using
 postgis 2.0, for example:
 select ST_Area('POLYGON((0 78.703946026662,0 0,179.999997913235
  0,179.999997913235 -33.0888306884702,0
  78.703946026662))'::geography,false);
      st_area
  127430010458336
 I'd expect changes from 2.1 to 2.2, as we changed to new spherical area
 code. I'm surprised to see changes from 2.0 to 2.1, but I see that also.
 Anyways, I'm not sure the answers are right, even when you get non-NaN
 answers. Will have to confirm that.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3393#comment:1>
