[postgis-tickets] r14490 - Add table inheritance support in ST_EstimatedExtent
Sandro Santilli strk at keybit.net
Tue Dec 15 03:19:14 PST 2015
Author: strk
Date: 2015-12-15 03:19:14 -0800 (Tue, 15 Dec 2015)
New Revision: 14490
   trunk/doc/reference_misc.xml
   trunk/postgis/gserialized_estimate.c
   trunk/postgis/postgis.sql.in
   trunk/regress/estimatedextent.sql
   trunk/regress/estimatedextent_expected
Ticket: #3391
Patch By: Alessandro Pasotti
Modified: trunk/doc/reference_misc.xml
--- trunk/doc/reference_misc.xml	2015-12-14 23:41:00 UTC (rev 14489)
+++ trunk/doc/reference_misc.xml	2015-12-15 11:19:14 UTC (rev 14490)
@@ -180,13 +180,22 @@
 			<paramdef><type>text </type> <parameter>schema_name</parameter></paramdef>
 			<paramdef><type>text </type> <parameter>table_name</parameter></paramdef>
 			<paramdef><type>text </type> <parameter>geocolumn_name</parameter></paramdef>
+			<paramdef><type>boolean </type> <parameter>parent_ony</parameter></paramdef>
 		  </funcprototype>
 		  <funcprototype>
 			<funcdef>box2d <function>ST_EstimatedExtent</function></funcdef>
+			<paramdef><type>text </type> <parameter>schema_name</parameter></paramdef>
 		  </funcprototype>
+		  <funcprototype>
+			<funcdef>box2d <function>ST_EstimatedExtent</function></funcdef>
+			<paramdef><type>text </type> <parameter>table_name</parameter></paramdef>
+			<paramdef><type>text </type> <parameter>geocolumn_name</parameter></paramdef>
+		  </funcprototype>
 		</funcsynopsis>
 	  </refsynopsisdiv>
@@ -195,7 +204,12 @@
 		<para>Return the 'estimated' extent of the given spatial table.
 			The estimated is taken from the geometry column's statistics. The
-			current schema will be used if not specified.</para>
+			current schema will be used if not specified. The default behavior
+			is to also use statistics collected from children tables (tables
+			with INHERITS) if available. If 'parent_ony' is set to TRUE, only
+			statistics for the given table are used and children tables are
+			ignored.
+		</para>
 		<para>For PostgreSQL>=8.0.0 statistics are gathered by VACUUM
 		ANALYZE and resulting extent will be about 95% of the real
Modified: trunk/postgis/gserialized_estimate.c
--- trunk/postgis/gserialized_estimate.c	2015-12-14 23:41:00 UTC (rev 14489)
+++ trunk/postgis/gserialized_estimate.c	2015-12-15 11:19:14 UTC (rev 14490)
@@ -849,13 +849,27 @@
 * by the selectivity functions and the debugging functions.
 static ND_STATS*
-pg_get_nd_stats(const Oid table_oid, AttrNumber att_num, int mode)
+pg_get_nd_stats(const Oid table_oid, AttrNumber att_num, int mode, bool only_parent)
-	HeapTuple stats_tuple;
+	HeapTuple stats_tuple = NULL;
 	ND_STATS *nd_stats;
-	/* First pull the stats tuple */
-	stats_tuple = SearchSysCache2(STATRELATT, table_oid, att_num);
+	/* First pull the stats tuple for the whole tree */
+	if ( ! only_parent )
+		POSTGIS_DEBUGF(2, "searching whole tree stats for \"%s\"", get_rel_name(table_oid)? get_rel_name(table_oid) : "NULL");
+		stats_tuple = SearchSysCache3(STATRELATT, table_oid, att_num, TRUE);
+		if ( stats_tuple )
+			POSTGIS_DEBUGF(2, "found whole tree stats for \"%s\"", get_rel_name(table_oid)? get_rel_name(table_oid) : "NULL");
+	/* Fall-back to main table stats only, if not found for whole tree or explicitly ignored */
+	if ( only_parent || ! stats_tuple )
+		POSTGIS_DEBUGF(2, "searching parent table stats for \"%s\"", get_rel_name(table_oid)? get_rel_name(table_oid) : "NULL");
+		stats_tuple = SearchSysCache2(STATRELATT, table_oid, att_num);
+		POSTGIS_DEBUGF(2, "found parent table stats for \"%s\"", get_rel_name(table_oid)? get_rel_name(table_oid) : "NULL");
 	if ( ! stats_tuple )
 		POSTGIS_DEBUGF(2, "stats for \"%s\" do not exist", get_rel_name(table_oid)? get_rel_name(table_oid) : "NULL");
@@ -878,9 +892,12 @@
 * Pull the stats object from the PgSQL system catalogs. The
 * debugging functions are taking human input (table names)
 * and columns, so we have to look those up first.
+* In case of parent tables whith INHERITS, when "only_parent"
+* is TRUE this function only searchs for stats in the parent
+* table ignoring any statistic collected from the children.
 static ND_STATS*
-pg_get_nd_stats_by_name(const Oid table_oid, const text *att_text, int mode)
+pg_get_nd_stats_by_name(const Oid table_oid, const text *att_text, int mode, bool only_parent)
 	const char *att_name = text2cstring(att_text);
 	AttrNumber att_num;
@@ -901,7 +918,7 @@
 		return NULL;
-	return pg_get_nd_stats(table_oid, att_num, mode);
+	return pg_get_nd_stats(table_oid, att_num, mode, only_parent);
@@ -1201,8 +1218,8 @@
 	                 get_rel_name(relid1) ? get_rel_name(relid1) : "NULL", relid1, get_rel_name(relid2) ? get_rel_name(relid2) : "NULL", relid2);
 	/* Pull the stats from the stats system. */
-	stats1 = pg_get_nd_stats(relid1, var1->varattno, mode);
-	stats2 = pg_get_nd_stats(relid2, var2->varattno, mode);
+	stats1 = pg_get_nd_stats(relid1, var1->varattno, mode, FALSE);
+	stats2 = pg_get_nd_stats(relid2, var2->varattno, mode, FALSE);
 	/* If we can't get stats, we have to stop here! */
 	if ( ! stats1 )
@@ -1944,13 +1961,18 @@
 	char *str;
 	text *json;
 	int mode = 2; /* default to 2D mode */
+	bool only_parent = FALSE; /* default to whole tree stats */
 	/* Check if we've been asked to not use 2d mode */
 	if ( ! PG_ARGISNULL(2) )
 		mode = text_p_get_mode(PG_GETARG_TEXT_P(2));
+	/* Check if we've been asked to only use stats from parent */
+	if ( ! PG_ARGISNULL(3) )
+		only_parent = PG_GETARG_BOOL(3);
 	/* Retrieve the stats object */
-	nd_stats = pg_get_nd_stats_by_name(table_oid, att_text, mode);
+	nd_stats = pg_get_nd_stats_by_name(table_oid, att_text, mode, only_parent);
 	if ( ! nd_stats )
 		elog(ERROR, "stats for \"%s.%s\" do not exist", get_rel_name(table_oid), text2cstring(att_text));
@@ -1983,7 +2005,7 @@
 		mode = text_p_get_mode(PG_GETARG_TEXT_P(3));
+	nd_stats = pg_get_nd_stats_by_name(table_oid, att_text, mode, FALSE);
 	if ( ! nd_stats )
@@ -2019,8 +2041,8 @@
-	nd_stats1 = pg_get_nd_stats_by_name(table_oid1, att_text1, mode);
-	nd_stats2 = pg_get_nd_stats_by_name(table_oid2, att_text2, mode);
+	nd_stats1 = pg_get_nd_stats_by_name(table_oid1, att_text1, mode, FALSE);
+	nd_stats2 = pg_get_nd_stats_by_name(table_oid2, att_text2, mode, FALSE);
 	if ( ! nd_stats1 )
 		elog(ERROR, "stats for \"%s.%s\" do not exist", get_rel_name(table_oid1), text2cstring(att_text1));
@@ -2189,17 +2211,29 @@
 	Oid tbl_oid;
 	ND_STATS *nd_stats;
 	GBOX *gbox;
-	if ( PG_NARGS() == 3 )
+	if ( PG_NARGS() == 4 )
 		nsp = text2cstring(PG_GETARG_TEXT_P(0));
 		tbl = text2cstring(PG_GETARG_TEXT_P(1));
 		col = PG_GETARG_TEXT_P(2);
 		nsp_tbl = palloc(strlen(nsp) + strlen(tbl) + 6);
 		sprintf(nsp_tbl, "\"%s\".\"%s\"", nsp, tbl);
 		tbl_oid = DatumGetObjectId(DirectFunctionCall1(regclassin, CStringGetDatum(nsp_tbl)));
 		pfree(nsp_tbl);
+	else if ( PG_NARGS() == 3 )
+		nsp = text2cstring(PG_GETARG_TEXT_P(0));
+		tbl = text2cstring(PG_GETARG_TEXT_P(1));
+		col = PG_GETARG_TEXT_P(2);
+		nsp_tbl = palloc(strlen(nsp) + strlen(tbl) + 6);
+		sprintf(nsp_tbl, "\"%s\".\"%s\"", nsp, tbl);
+		tbl_oid = DatumGetObjectId(DirectFunctionCall1(regclassin, CStringGetDatum(nsp_tbl)));
+		pfree(nsp_tbl);
 	else if ( PG_NARGS() == 2 )
 		tbl = text2cstring(PG_GETARG_TEXT_P(0));
@@ -2216,7 +2250,7 @@
 	/* Estimated extent only returns 2D bounds, so use mode 2 */
-	nd_stats = pg_get_nd_stats_by_name(tbl_oid, col, 2);
+	nd_stats = pg_get_nd_stats_by_name(tbl_oid, col, 2, only_parent);
 	/* Error out on no stats */
 	if ( ! nd_stats )
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in	2015-12-14 23:41:00 UTC (rev 14489)
+++ trunk/postgis/postgis.sql.in	2015-12-15 11:19:14 UTC (rev 14490)
@@ -961,6 +961,11 @@
 -- ST_ESTIMATED_EXTENT( <schema name>, <table name>, <column name> )
+-- Availability: 2.3.0
+CREATE OR REPLACE FUNCTION ST_EstimatedExtent(text,text,text,boolean) RETURNS box2d AS
+	'MODULE_PATHNAME', 'gserialized_estimated_extent'
+	LANGUAGE 'c' IMMUTABLE STRICT SECURITY DEFINER;
 -- Availability: 2.1.0
 CREATE OR REPLACE FUNCTION ST_EstimatedExtent(text,text,text) RETURNS box2d AS
Modified: trunk/regress/estimatedextent.sql
--- trunk/regress/estimatedextent.sql	2015-12-14 23:41:00 UTC (rev 14489)
+++ trunk/regress/estimatedextent.sql	2015-12-15 11:19:14 UTC (rev 14490)
@@ -26,4 +26,165 @@
 round(st_ymin(e.e)::numeric, 5), round(st_ymax(e.e)::numeric, 5) from e;
 drop table t;
+-- #3391
+-- drop table if exists p cascade;
+create table p(g geometry);
+create table c1() inherits (p);
+create table c2() inherits (p);
+analyze c1;
+analyze c2;
+analyze p;
+-- #3391.1
+with e as ( select ST_EstimatedExtent('c1','g') as e )
+select '#3391.1', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
+round(st_ymin(e.e)::numeric, 2), round(st_ymax(e.e)::numeric, 2) from e;
+-- #3391.2
+with e as ( select ST_EstimatedExtent('c2','g') as e )
+select '#3391.2', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
+-- #3391.3
+with e as ( select ST_EstimatedExtent('p','g') as e )
+select '#3391.3', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
+insert into c1 values ('Point(0 0)'::geometry);
+insert into c1 values ('Point(1 1)'::geometry);
+analyze c1;
+analyze c2;
+analyze p;
+-- #3391.4
+select '#3391.4', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
+-- #3391.5
+select '#3391.5', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
+-- #3391.6
+select '#3391.6', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
+insert into c2 values ('Point(0 0)'::geometry);
+insert into c2 values ('Point(-1 -1)'::geometry);
+analyze c1;
+analyze c2;
+analyze p;
+-- #3391.7
+select '#3391.7', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
+-- #3391.8
+select '#3391.8', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
+-- #3391.9
+select '#3391.9', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
+insert into p values ('Point(1 1)'::geometry);
+insert into p values ('Point(2 2)'::geometry);
+analyze c1;
+analyze c2;
+analyze p;
+-- #3391.10
+select '#3391.10', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
+-- #3391.11
+select '#3391.11', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
+-- #3391.12
+select '#3391.12', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
+-- test calls with 3th parameter
+delete from p where 't';
+delete from c1 where 't';
+delete from c2 where 't';
+delete from pg_statistic where starelid = 'p'::regclass;
+delete from pg_statistic where starelid = 'c1'::regclass;
+delete from pg_statistic where starelid = 'c2'::regclass;
+analyze c1;
+analyze c2;
+analyze p;
+-- #3391.13
+with e as ( select ST_EstimatedExtent('public','p','g','t') as e )
+select '#3391.13', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
+-- #3391.14
+with e as ( select ST_EstimatedExtent('public','p','g','f') as e )
+select '#3391.14', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
+-- #3391.15
+with e as ( select ST_EstimatedExtent('public','c1','g', 't') as e )
+select '#3391.15', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
+-- #3391.16
+with e as ( select ST_EstimatedExtent('public','c1','g', 'f') as e )
+select '#3391.16', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
+analyze c1;
+analyze c2;
+analyze p;
+-- #3391.17
+select '#3391.17', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
+-- #3391.18
+select '#3391.18', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
+-- #3391.19
+select '#3391.19', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
+-- #3391.20
+select '#3391.20', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
+drop table p cascade;
Modified: trunk/regress/estimatedextent_expected
--- trunk/regress/estimatedextent_expected	2015-12-14 23:41:00 UTC (rev 14489)
+++ trunk/regress/estimatedextent_expected	2015-12-15 11:19:14 UTC (rev 14490)
@@ -5,3 +5,24 @@
 ERROR:  stats for "t.g" do not exist
 #877.4|-10.15000|20.15000|-50.40000|30.40000
 #877.5|-10.15000|20.15000|-50.40000|30.40000
+ERROR:  stats for "c1.g" do not exist
+ERROR:  stats for "c2.g" do not exist
+ERROR:  stats for "p.g" do not exist
+#3391.4|0.00|1.00|0.00|1.00
+#3391.6|0.00|1.00|0.00|1.00
+#3391.7|0.00|1.00|0.00|1.00
+#3391.8|-1.00|0.00|-1.00|0.00
+#3391.9|-1.01|1.01|-1.01|1.01
+#3391.10|0.00|1.00|0.00|1.00
+#3391.11|-1.00|0.00|-1.00|0.00
+#3391.12|-1.01|2.02|-1.01|2.02
+#3391.17|0.00|1.00|0.00|1.00
+#3391.19|0.00|1.00|0.00|1.00
+#3391.20|0.00|1.00|0.00|1.00
+NOTICE:  drop cascades to 2 other objects
