[postgis-tickets] [PostGIS] #3380: "geometry crosses edge" with 1e-2 tolerance
PostGIS trac at osgeo.org
Thu Dec 17 01:22:28 PST 2015
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 2.0.8
 Component:  topology  |    Version:  2.0.x
Resolution:            |   Keywords:
Comment (by strk):
 Removal of consecutive points within tolerance also triggers failures in
 the existing testsuite,
 like the following:
 -#1714.2|E*|74
 +ERROR:  SQL/MM Spatial exception - curve not simple
 The idea looks promising, but it'd take going trough each and every
 failing test to see what's going on (most of them might be different but
 still acceptable results, except the case above of non-simple curve)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3380#comment:13>
