[postgis-tickets] r14492 - #3399, ST_GeneratePoints
Paul Ramsey pramsey at cleverelephant.ca
Thu Dec 17 10:12:24 PST 2015
Author: pramsey
Date: 2015-12-17 10:12:23 -0800 (Thu, 17 Dec 2015)
New Revision: 14492
   trunk/NEWS
   trunk/doc/reference_processing.xml
   trunk/liblwgeom/cunit/cu_algorithm.c
   trunk/liblwgeom/liblwgeom.h.in
   trunk/liblwgeom/lwgeom_geos.c
   trunk/postgis/lwgeom_geos.c
   trunk/postgis/postgis.sql.in
Modified: trunk/NEWS
--- trunk/NEWS	2015-12-17 07:30:43 UTC (rev 14491)
+++ trunk/NEWS	2015-12-17 18:12:23 UTC (rev 14492)
@@ -10,6 +10,7 @@
   - TopoGeom_addElement, TopoGeom_remElement (Sandro Santilli)
   - populate_topology_layer (Sandro Santilli)
   - #2259 ST_Voronoi (Dan Baston)
+  - #3339 ST_GeneratePoints (Paul Ramsey)
 PostGIS 2.2.0
 2015/10/07
Modified: trunk/doc/reference_processing.xml
--- trunk/doc/reference_processing.xml	2015-12-17 07:30:43 UTC (rev 14491)
+++ trunk/doc/reference_processing.xml	2015-12-17 18:12:23 UTC (rev 14492)
@@ -3653,4 +3653,43 @@
 		</para>
 	  </refsection>
 	</refentry>
+	<refentry id="ST_GeneratePoints">
+	  <refnamediv>
+		<refname>ST_GeneratePoints</refname>
+		<refpurpose>Converts a polygon or multi-polygon into a multi-point composed of randomly location points within the original areas.</refpurpose>
+	  </refnamediv>
+	  <refsynopsisdiv>
+		<funcsynopsis>
+		  <funcprototype>
+			<funcdef>geometry <function>ST_GeneratePoints</function></funcdef>
+			<paramdef>
+				<parameter>g</parameter>
+				<type>geometry</type>
+			</paramdef>
+			<paramdef>
+				<parameter>npoints</parameter>
+				<type>numeric</type>
+			</paramdef>
+		  </funcprototype>
+		</funcsynopsis>
+	  </refsynopsisdiv>
+	  <refsection>
+		<title>Description</title>
+		<para>
+			ST_GeneratePoints generates pseudo-random points until the requested number are
+			found within the input area.
+		</para>
+		<para>Availability: 2.3.0</para>
+	  </refsection>
+	</refentry>
 </sect1>
Modified: trunk/liblwgeom/cunit/cu_algorithm.c
--- trunk/liblwgeom/cunit/cu_algorithm.c	2015-12-17 07:30:43 UTC (rev 14491)
+++ trunk/liblwgeom/cunit/cu_algorithm.c	2015-12-17 18:12:23 UTC (rev 14492)
@@ -982,6 +982,47 @@
 		lwfree(ewkt);
+static void test_point_density(void)
+	LWGEOM *geom;
+	LWMPOINT *mpt;
+	// char *ewkt;
+	/* POLYGON */
+	geom = lwgeom_from_wkt("POLYGON((1 0,0 1,1 2,2 1,1 0))", LW_PARSER_CHECK_NONE);
+	mpt = lwgeom_to_points(geom, 100);
+	CU_ASSERT_EQUAL(mpt->ngeoms,100);
+	// ewkt = lwgeom_to_ewkt((LWGEOM*)mpt);
+	// printf("%s\n", ewkt);
+	// lwfree(ewkt);
+	lwmpoint_free(mpt);
+	mpt = lwgeom_to_points(geom, 1);
+	CU_ASSERT_EQUAL(mpt->ngeoms,1);
+	mpt = lwgeom_to_points(geom, 0);
+	CU_ASSERT_EQUAL(mpt, NULL);
+	lwgeom_free(geom);
+	/* MULTIPOLYGON */
+	geom = lwgeom_from_wkt("MULTIPOLYGON(((10 0,0 10,10 20,20 10,10 0)),((0 0,5 0,5 5,0 5,0 0)))", LW_PARSER_CHECK_NONE);
+	mpt = lwgeom_to_points(geom, 1000);
+	CU_ASSERT_EQUAL(mpt->ngeoms,1000);
 ** Used by test harness to register the tests in this file.
@@ -1007,4 +1048,5 @@
 	PG_ADD_TEST(suite,test_isclosed);
 	PG_ADD_TEST(suite,test_lwgeom_simplify);
 	PG_ADD_TEST(suite,test_lw_arc_center);
+	PG_ADD_TEST(suite,test_point_density);
Modified: trunk/liblwgeom/liblwgeom.h.in
--- trunk/liblwgeom/liblwgeom.h.in	2015-12-17 07:30:43 UTC (rev 14491)
+++ trunk/liblwgeom/liblwgeom.h.in	2015-12-17 18:12:23 UTC (rev 14492)
@@ -1440,6 +1440,13 @@
 extern LWPOLY *lwpoly_segmentize2d(LWPOLY *line, double dist);
 extern LWCOLLECTION *lwcollection_segmentize2d(LWCOLLECTION *coll, double dist);
+ * Point density functions
+extern LWMPOINT *lwpoly_to_points(const LWPOLY *poly, int npoints);
+extern LWMPOINT *lwmpoly_to_points(const LWMPOLY *mpoly, int npoints);
+extern LWMPOINT *lwgeom_to_points(const LWGEOM *lwgeom, int npoints);
 * Calculate the GeoHash (http://geohash.org) string for a geometry. Caller must free.
Modified: trunk/liblwgeom/lwgeom_geos.c
--- trunk/liblwgeom/lwgeom_geos.c	2015-12-17 07:30:43 UTC (rev 14491)
+++ trunk/liblwgeom/lwgeom_geos.c	2015-12-17 18:12:23 UTC (rev 14492)
@@ -29,6 +29,7 @@
 #include "lwgeom_log.h"
 #include <stdlib.h>
+#include <time.h>
 LWTIN *lwtin_from_geos(const GEOSGeometry *geom, int want3d);
@@ -1546,6 +1547,265 @@
 	return lwgeom_result;
+static void shuffle(void *array, size_t n, size_t size) {
+    char tmp[size];
+    char *arr = array;
+    size_t stride = size;
+    if (n > 1) {
+        size_t i;
+        for (i = 0; i < n - 1; ++i) {
+            size_t rnd = (size_t) rand();
+            size_t j = i + rnd / (RAND_MAX / (n - i) + 1);
+            memcpy(tmp, arr + j * stride, size);
+            memcpy(arr + j * stride, arr + i * stride, size);
+            memcpy(arr + i * stride, tmp, size);
+LWMPOINT*
+lwpoly_to_points(const LWPOLY *lwpoly, int npoints)
+	double area, bbox_area, bbox_width, bbox_height;
+	GBOX bbox;
+	const LWGEOM *lwgeom = (LWGEOM*)lwpoly;
+	int sample_npoints, sample_sqrt, sample_width, sample_height;
+	double sample_cell_size;
+	int i, j;
+	int iterations = 0;
+	int npoints_generated = 0;
+	int npoints_tested = 0;
+	GEOSGeometry *g;
+	const GEOSPreparedGeometry *gprep;
+	GEOSGeometry *gpt;
+	GEOSCoordSequence *gseq;
+	LWMPOINT *mpt;
+	int srid = lwgeom_get_srid(lwgeom);
+	int done = 0;
+	int *cells;
+	if (lwgeom_get_type(lwgeom) != POLYGONTYPE)
+		lwerror("%s: only polygons supported", __func__);
+		return NULL;
+	if (npoints == 0 || lwgeom_is_empty(lwgeom))
+		return NULL;
+		// return lwmpoint_construct_empty(lwgeom_get_srid(poly), lwgeom_has_z(poly), lwgeom_has_m(poly));
+	if (!lwpoly->bbox)
+		lwgeom_calculate_gbox(lwgeom, &bbox);
+	else
+		bbox = *(lwpoly->bbox);
+	area = lwpoly_area(lwpoly);
+	bbox_width = bbox.xmax - bbox.xmin;
+	bbox_height = bbox.ymax - bbox.ymin;
+	bbox_area = bbox_width * bbox_height;
+	if (area == 0.0 || bbox_area == 0.0)
+		lwerror("%s: zero area input polygon, TBD", __func__);
+		return NULL;
+	/* Gross up our test set a bit to increase odds of getting */
+	/* coverage in one pass */
+	sample_npoints = npoints * bbox_area / area;
+	/* We're going to generate points using a sample grid */
+	/* as described http://lin-ear-th-inking.blogspot.ca/2010/05/more-random-points-in-jts.html */
+	/* to try and get a more uniform "random" set of points */
+	/* So we have to figure out how to stick a grid into our box */
+	sample_sqrt = lround(sqrt(sample_npoints));
+	if (sample_sqrt == 0)
+		sample_sqrt = 1;
+	/* Calculate the grids we're going to randomize within */
+	if (bbox_width > bbox_height)
+		sample_width = sample_sqrt;
+		sample_height = ceil((double)sample_npoints / (double)sample_width);
+		sample_cell_size = bbox_width / sample_width;
+	else
+		sample_height = sample_sqrt;
+		sample_width = ceil((double)sample_npoints / (double)sample_height);
+		sample_cell_size = bbox_height / sample_height;
+	/* Prepare the polygon for fast true/false testing */
+	initGEOS(lwnotice, lwgeom_geos_error);
+	g = (GEOSGeometry *)LWGEOM2GEOS(lwgeom, 0);
+	if (!g)
+		lwerror("%s: Geometry could not be converted to GEOS: %s", __func__, lwgeom_geos_errmsg);
+		return NULL;
+	gprep = GEOSPrepare(g);
+	/* Get an empty multi-point ready to return */
+	mpt = lwmpoint_construct_empty(srid, 0, 0);
+	/* Init random number generator */
+	srand(time(NULL));
+	/* Now we fill in an array of cells, and then shuffle that array, */
+	/* so we can visit the cells in random order to avoid visual ugliness */
+	/* caused by visiting them sequentially */
+	cells = lwalloc(2*sizeof(int)*sample_height*sample_width);
+	for (i = 0; i < sample_width; i++)
+		for (j = 0; j < sample_height; j++)
+			cells[2*(i*sample_height+j)] = i;
+			cells[2*(i*sample_height+j)+1] = j;
+	shuffle(cells, sample_height*sample_width, 2*sizeof(int));
+	/* Start testing points */
+	while (npoints_generated < npoints)
+		iterations++;
+		for (i = 0; i < sample_width*sample_height; i++)
+			int contains = 0;
+			double y = bbox.ymin + cells[2*i] * sample_cell_size;
+			double x = bbox.xmin + cells[2*i+1] * sample_cell_size;
+			x += rand() * sample_cell_size / RAND_MAX;
+			y += rand() * sample_cell_size / RAND_MAX;
+			if (x >= bbox.xmax || y >= bbox.ymax)
+				continue;
+			gseq = GEOSCoordSeq_create(1, 2);
+			GEOSCoordSeq_setX(gseq, 0, x);
+			GEOSCoordSeq_setY(gseq, 0, y);
+			gpt = GEOSGeom_createPoint(gseq);
+			contains = GEOSPreparedIntersects(gprep, gpt);
+	        GEOSGeom_destroy(gpt);
+			if (contains == 2)
+		        GEOSPreparedGeom_destroy(gprep);
+		        GEOSGeom_destroy(g);
+		        lwerror("%s: GEOS exception on PreparedContains: %s", __func__, lwgeom_geos_errmsg);
+		        return NULL;
+			if (contains)
+				npoints_generated++;
+				mpt = lwmpoint_add_lwpoint(mpt, lwpoint_make2d(srid, x, y));
+				if (npoints_generated == npoints)
+					done = 1;
+					break;
+			/* Short-circuit check for ctrl-c occasionally */
+			npoints_tested++;
+			if (npoints_tested % 10000 == 0)
+				LW_ON_INTERRUPT(GEOSPreparedGeom_destroy(gprep); GEOSGeom_destroy(g); return NULL);
+			if (done) break;
+		if (done || iterations > 100) break;
+	lwfree(cells);
+	return mpt;
+* Allocate points to sub-geometries by area, then call lwgeom_poly_to_points
+* and bundle up final result in a single multipoint.
+LWMPOINT*
+lwmpoly_to_points(const LWMPOLY *lwmpoly, int npoints)
+	const LWGEOM *lwgeom = (LWGEOM*)lwmpoly;
+	double area;
+	int i;
+	LWMPOINT *mpt = NULL;
+	if (lwgeom_get_type(lwgeom) != MULTIPOLYGONTYPE)
+		lwerror("%s: only multipolygons supported", __func__);
+		return NULL;
+		return NULL;
+	area = lwgeom_area(lwgeom);
+	for (i = 0; i < lwmpoly->ngeoms; i++)
+		double sub_area = lwpoly_area(lwmpoly->geoms[i]);
+		int sub_npoints = lround(npoints * sub_area / area);
+		if(sub_npoints > 0)
+			LWMPOINT *sub_mpt = lwpoly_to_points(lwmpoly->geoms[i], sub_npoints);
+			if (!mpt)
+				mpt = sub_mpt;
+			else
+				int j;
+				for (j = 0; j < sub_mpt->ngeoms; j++)
+					mpt = lwmpoint_add_lwpoint(mpt, sub_mpt->geoms[j]);
+				/* Just free the shell, leave the underlying lwpoints alone, as they
+				   are now owed by the returning multipoint */
+				lwgeom_release((LWGEOM*)sub_mpt);
+	return mpt;
+LWMPOINT*
+lwgeom_to_points(const LWGEOM *lwgeom, int npoints)
+	switch(lwgeom_get_type(lwgeom))
+		case MULTIPOLYGONTYPE:
+			return lwmpoly_to_points((LWMPOLY*)lwgeom, npoints);
+		case POLYGONTYPE:
+			return lwpoly_to_points((LWPOLY*)lwgeom, npoints);
+		default:
+			lwerror("%s: unsupported geometry type '%s'", __func__, lwtype_name(lwgeom_get_type(lwgeom)));
+			return NULL;
 LWTIN *lwtin_from_geos(const GEOSGeometry *geom, int want3d) {
 	int type = GEOSGeomTypeId(geom);
 	int hasZ;
Modified: trunk/postgis/lwgeom_geos.c
--- trunk/postgis/lwgeom_geos.c	2015-12-17 07:30:43 UTC (rev 14491)
+++ trunk/postgis/lwgeom_geos.c	2015-12-17 18:12:23 UTC (rev 14492)
@@ -33,6 +33,7 @@
 #include "utils/array.h"
 #include "utils/builtins.h"
 #include "utils/lsyscache.h"
+#include "utils/numeric.h"
 #if POSTGIS_PGSQL_VERSION >= 93
 #include "access/htup_details.h"
@@ -917,7 +918,48 @@
 	PG_RETURN_POINTER(result);
+* Generate a field of random points within the area of a
+* polygon or multipolygon. Throws an error for other geometry
+* types.
+Datum ST_GeneratePoints(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(ST_GeneratePoints);
+	GSERIALIZED	*gser_input;
+	GSERIALIZED *gser_result;
+	LWGEOM *lwgeom_input;
+	LWGEOM *lwgeom_result;
+	int32 npoints;
+	gser_input = PG_GETARG_GSERIALIZED_P(0);
+	npoints = DatumGetInt32(DirectFunctionCall1(numeric_int4, PG_GETARG_DATUM(1)));
+	/* Smartasses get nothing back */
+	if (npoints < 0)
+		PG_RETURN_NULL();
+	/* Types get checked in the code, we'll keep things small out there */
+	lwgeom_input = lwgeom_from_gserialized(gser_input);
+	lwgeom_result = (LWGEOM*)lwgeom_to_points(lwgeom_input, npoints);
+	lwgeom_free(lwgeom_input);
+	PG_FREE_IF_COPY(gser_input, 0);
+	/* Return null as null */
+	if (!lwgeom_result)
+		PG_RETURN_NULL();
+	/* Serialize and return */
+	gser_result = gserialized_from_lwgeom(lwgeom_result, 0);
+	lwgeom_free(lwgeom_result);
+	PG_RETURN_POINTER(gser_result);
 * Compute at offset curve to a line
 Datum ST_OffsetCurve(PG_FUNCTION_ARGS);
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in	2015-12-17 07:30:43 UTC (rev 14491)
+++ trunk/postgis/postgis.sql.in	2015-12-17 18:12:23 UTC (rev 14492)
@@ -3197,6 +3197,13 @@
        LANGUAGE 'c' IMMUTABLE STRICT
        COST 100;
+-- Availability: 2.3.0
+CREATE OR REPLACE FUNCTION ST_GeneratePoints(area geometry, npoints numeric)
+       RETURNS geometry
+       AS 'MODULE_PATHNAME','ST_GeneratePoints'
+       LANGUAGE 'c' IMMUTABLE STRICT
+       COST 400;
 -- PostGIS equivalent function: convexhull(geometry)
 CREATE OR REPLACE FUNCTION ST_ConvexHull(geometry)
 	RETURNS geometry
