[postgis-tickets] r14499 - Fix images for ST_GeneratePoints example
Regina Obe lr at pcorp.us
Thu Dec 17 23:02:14 PST 2015
Author: robe
Date: 2015-12-17 23:02:14 -0800 (Thu, 17 Dec 2015)
New Revision: 14499
Added:
   trunk/doc/html/image_src/st_generatepoints02.wkt
   trunk/doc/html/image_src/Makefile.in
   trunk/doc/html/image_src/st_generatepoints01.wkt
   trunk/doc/reference_processing.xml
references #3399
Modified: trunk/doc/html/image_src/Makefile.in
--- trunk/doc/html/image_src/Makefile.in	2015-12-18 01:37:40 UTC (rev 14498)
+++ trunk/doc/html/image_src/Makefile.in	2015-12-18 07:02:14 UTC (rev 14499)
@@ -64,6 +64,7 @@
 	../images/st_extrude01.png \
 	../images/st_extrude03.png \
 	../images/st_generatepoints01.png \
+	../images/st_generatepoints02.png \
 	../images/st_issimple01.png \
 	../images/st_issimple02.png \
 	../images/st_issimple03.png \
Modified: trunk/doc/html/image_src/st_generatepoints01.wkt
--- trunk/doc/html/image_src/st_generatepoints01.wkt	2015-12-18 01:37:40 UTC (rev 14498)
+++ trunk/doc/html/image_src/st_generatepoints01.wkt	2015-12-18 07:02:14 UTC (rev 14499)
@@ -1,2 +1,2 @@
-Style2;POLYGON((150 90,149.039264020162 80.2454838991936,146.193976625564 70.8658283817455,141.573480615127 62.2214883490199,135.355339059327 54.6446609406727,127.77851165098 48.4265193848728,119.134171618255 43.8060233744357,109.754516100806 40.9607359798385,100 40,90.2454838991937 40.9607359798385,80.8658283817456 43.8060233744356,72.22148834902 48.4265193848727,64.6446609406727 54.6446609406725,58.4265193848728 62.2214883490198,53.8060233744357 70.8658283817454,50.9607359798385 80.2454838991934,50 89.9999999999998,50.9607359798384 99.7545161008062,53.8060233744356 109.134171618254,58.4265193848726 117.77851165098,64.6446609406725 125.355339059327,72.2214883490197 131.573480615127,80.8658283817453 136.193976625564,90.2454838991934 139.039264020161,99.9999999999998 140,109.754516100806 139.039264020162,119.134171618254 136.193976625564,127.77851165098 131.573480615127,135.355339059327 125.355339059327,141.573480615127 117.77851165098,146.193976625564 109.134171618255,149.0392640201
 62 99.7545161008065,150 90))
+Style2;POLYGON((142.928932188135 157.071067811865,144.444297669804 158.314696123025,146.173165676349 159.238795325113,148.049096779839 159.807852804032,150 160,151.950903220161 159.807852804032,153.826834323651 159.238795325113,155.555702330196 158.314696123025,157.071067811865 157.071067811865,158.314696123025 155.555702330196,159.238795325113 153.826834323651,159.807852804032 151.950903220161,160 150,160 50,159.807852804032 48.0490967798387,159.238795325113 46.1731656763491,158.314696123025 44.444297669804,157.071067811865 42.9289321881345,155.555702330196 41.6853038769745,153.826834323651 40.7612046748871,151.950903220161 40.1921471959677,150 40,148.049096779839 40.1921471959677,146.173165676349 40.7612046748871,144.444297669804 41.6853038769745,142.928932188135 42.9289321881345,141.685303876975 44.444297669804,140.761204674887 46.1731656763491,140.192147195968 48.0490967798387,140 50,140 125.857864376269,57.0710678118655 42.9289321881345,55.555702330196 41.6853038769745,53.82683
 43236509 40.7612046748871,51.9509032201613 40.1921471959677,50 40,48.0490967798387 40.1921471959677,46.1731656763491 40.7612046748871,44.444297669804 41.6853038769745,42.9289321881345 42.9289321881345,41.6853038769746 44.444297669804,40.7612046748871 46.1731656763491,40.1921471959677 48.0490967798387,40 50,40.1921471959677 51.9509032201613,40.7612046748871 53.8268343236509,41.6853038769745 55.555702330196,42.9289321881345 57.0710678118655,142.928932188135 157.071067811865))
 Style1-thinline;MULTIPOINT(102.722861415448 109.63774529252,149.121982482376 109.73967711417,143.583483382672 71.2656025879696,43.6127811517685 46.1928159428694,64.0937528611103 64.3971068453017,158.682821131016 128.593401898251,144.217047639393 142.958464308603,143.193456831568 81.4453566087832,137.923520615253 135.276955473495,149.037141026032 48.2552568132572,85.2284310434278 92.0542008728294,107.117526779992 101.481368449965)
Added: trunk/doc/html/image_src/st_generatepoints02.wkt
--- trunk/doc/html/image_src/st_generatepoints02.wkt	                        (rev 0)
+++ trunk/doc/html/image_src/st_generatepoints02.wkt	2015-12-18 07:02:14 UTC (rev 14499)
@@ -0,0 +1 @@
Modified: trunk/doc/reference_processing.xml
--- trunk/doc/reference_processing.xml	2015-12-18 01:37:40 UTC (rev 14498)
+++ trunk/doc/reference_processing.xml	2015-12-18 07:02:14 UTC (rev 14499)
@@ -3700,7 +3700,8 @@
 						<para><informalfigure>
 						<mediaobject>
 						  <imageobject>
-							<imagedata fileref="images/st_buffer01.png" />
+							<imagedata fileref="images/st_generatepoints01.png" />
+						  </imageobject>" />
 						  </imageobject>
 						  <caption><para>Original Polygon</para></caption>
 						</mediaobject>
@@ -3711,7 +3712,7 @@
 					<entry><para><informalfigure>
 						<mediaobject>
 						  <imageobject>
-							<imagedata fileref="images/st_generatepoints01.png" />
+							<imagedata fileref="images/st_generatepoints02.png" />
 						  </imageobject>
 						  <caption><para>Generated 12 Points overlaid on top of original polygon</para></caption>
 						</mediaobject>
