[postgis-tickets] [PostGIS] #3402: geometry crosses edges with 0 tolerance
PostGIS trac at osgeo.org
Fri Dec 18 03:16:24 PST 2015
 Reporter:  strk      |      Owner:  strk
     Type:  defect    |     Status:  new
 Priority:  medium    |  Milestone:  PostGIS 2.1.9
Component:  topology  |    Version:  2.1.x
 Keywords:            |
 The attached .zip file contains a relatively small dataset that triggers
 an "edge-crosses-edge" exception when loaded in the PostGIS topology.
 It's to be double-checked as I saw the exception raised by PostGIS-2.1 but
 not by PostGIS trunk (but I might have some local changes).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3402>
