[postgis-tickets] r14521 - add pcre for address_standardizer, and other updates I forgot to committ
Regina Obe lr at pcorp.us
Sat Dec 26 01:53:48 PST 2015
Author: robe
Date: 2015-12-26 01:53:47 -0800 (Sat, 26 Dec 2015)
New Revision: 14521
   buildbots/debian/jenkins_setup.txt
Modified: buildbots/debian/jenkins_setup.txt
--- buildbots/debian/jenkins_setup.txt	2015-12-23 19:34:10 UTC (rev 14520)
+++ buildbots/debian/jenkins_setup.txt	2015-12-26 09:53:47 UTC (rev 14521)
@@ -25,6 +25,10 @@
 apt-get install libproj9 libproj-dev proj-bin proj-data
 apt-get install g++
+#for address_standardizer
+apt-get install libpcre3-dev
 apt-get update
 apt-get install jenkins
@@ -43,6 +47,7 @@
 #make it the default
 sudo apt-get install oracle-java7-set-default
 apt-get install git
@@ -127,4 +132,5 @@
 SCM API Plugin
 SVN Publisher plugin
 Text Finder Run Condition Plugin
-Embeddable Build Status Plugin  (for showing image of build status)
\ No newline at end of file
+Embeddable Build Status Plugin  (for showing image of build status)
+Build Authorization Token Root Plugin (for triggering builds via scm hooks)
