[postgis-tickets] [PostGIS] #3409: Winnie's 9.5rc1 32-bit regress are failing on raster
PostGIS trac at osgeo.org
Sun Dec 27 09:46:19 PST 2015
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  PostGIS 2.2.1
Component:  buildbots  |    Version:  2.2.x
 Keywords:             |
 Ever since I upgrade the 9.5 32-bit windows the 2.2 and 2.3 of winnie's
 have been failing.  I'm sure it's some configuration issue I messed up
 during 9.5rc1 upgrade.
 Error is below:
 2.1.0w32gcc481/lib -L/projects/curl/rel-curl-7.39.0w32gcc481/lib
 -L/projects/proj/rel-4.9.1w32gcc481/lib
 Makefile:78: recipe for target `check' failed
 make[3]: *** [check] Error 57
 make[3]: Leaving directory
 `/projects/postgis/branches/2.2/raster/test/cunit'
 Makefile:15: recipe for target `core-check' failed
 make[2]: *** [core-check] Error 2
 make[2]: Leaving directory `/projects/postgis/branches/2.2/raster/test'
 Makefile:65: recipe for target `check' failed
 make[1]: *** [check] Error 2
 make[1]: Leaving directory `/projects/postgis/branches/2.2/raster'
 GNUmakefile:16: recipe for target `check' failed
 make: *** [check] Error 1
 Anyway will try to fix in next couple of days.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3409>
