[postgis-tickets] [PostGIS] #3415: fails to build on OS X because of --exclude-libs
PostGIS trac at osgeo.org
Wed Dec 30 17:16:33 PST 2015
  Reporter:  petere                 |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  high                   |  Milestone:  PostGIS 2.2.1
 Component:  build/upgrade/install  |    Version:  2.2.x
Resolution:                         |   Keywords:
Comment (by gdt):
 FWIW, I see the same failure trying to build 2.2.0 under pkgsrc on OS X
 10.9.
 After manually removing --exclude-libs from config.status and rerunning
 config.status, postgis not only builds but make check almost worked,
 getting into raster tests.  It failed with some proj dynamic linking stuff
 that may be a pkgsrc bug.   The suggested fix seems right to me too.
 PostgreSQL 9.3.10 on x86_64-apple-darwin13, compiled by Apple LLVM version
 6.0 (clang-600.0.57) (based on LLVM 3.5svn), 64-bit
   Postgis 2.2.0 - r14208 - 2015-12-31 00:26:39
   scripts 2.2.0 r14208
   GEOS: 3.5.0-CAPI-1.9.0 r4084
   PROJ: Rel. 4.9.2, 08 September 2015
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3415#comment:1>
