[postgis-tickets] [PostGIS] #3046: topology.GetRingEdges return wrong ring when edge.next_left/right = edge
PostGIS trac at osgeo.org
Fri Feb 20 02:28:07 PST 2015
  Reporter:  remic     |       Owner:  strk
      Type:  defect    |      Status:  closed
  Priority:  medium    |   Milestone:
 Component:  topology  |     Version:  2.1.x
Resolution:  invalid   |    Keywords:
Comment(by remic):
 Hm in my opinion it is an error.
 In no case should you have the same walk by walking forward or backward.
 Now if calling the function for +X and -X gives the same result (except
 for isolated edge).
 It is the case here,
 because whatever the sign you always end up turning in the same direction.
 Cheers,
 Rémi-C
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3046#comment:2>
