[postgis-tickets] [PostGIS] #2227: Visvalingam line generalization function
PostGIS trac at osgeo.org
Mon Jan 12 09:37:40 PST 2015
 Reporter:  strk         |       Owner:  nicklas
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.2.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by strk):
 Should the function be called ST_Visvalingam, for clearness ?
 Also, couldn't 0 be a valid threshold value for a simplification ? To only
 remove vertices on the segment defined by their adjacent ones.
 About first/last point, we have a similar issue with ST_Simplify, and the
 latest idea was to use a kind of "policy" argument. I'm on a slow
 connection now but if you search ST_Simplify in trac you should find the
 previous discussion.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2227#comment:6>
