[postgis-tickets] [PostGIS] #3013: Dimension-based geometry column constraints
PostGIS trac at osgeo.org
Tue Jan 13 02:31:22 PST 2015
 Reporter:  mpd          |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  low          |   Milestone:
Component:  postgis      |     Version:  trunk
 Keywords:               |
 Geometry column constraints are type-based, eg POINT, LINESTRING, POLYGON.
 In the case of an awful lot of polygonal (dimension==2) data this makes it
 necessary to use GEOMETRY (because so much data contains MULTIPOLYGONS as
 well as POLYGONS, eg any dataset of the countries of the world).
 If the type constraints could also, optionally, be dimension==0 (ie POINT
 or MULTIPOINT), dimension==1 (ie LINESTRING or MULTILINESTRING) or
 dimension==2 (ie POLYGON or MULTIPOLYGON), then GEOMETRY would not have to
 be used so frequently.
 Newer geometry types could also be added to the relevant constraint, eg
 CURVEPOLYGON to dimension==2, TIN to dimension==3, etc.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3013>
