[postgis-tickets] [PostGIS] #2227: Visvalingam line generalization function
PostGIS trac at osgeo.org
Thu Jan 15 02:51:35 PST 2015
 Reporter:  strk         |       Owner:  nicklas
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.2.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by strk):
 Thanks about clarification on the effectiveness of the per-vertex
 indexing.
 I'm fine with the tagging-only function being named as it is currently
 (ST_SetEffectiveArea) or renamed to include some reference to Visvalingam
 and Whyatt.
 The ST_Simplify version picking ST_SimplifyDP or ST_SimplifyVW
 (Visvalingam and Whyatt) would be in SQL language, thus "inlinable".
 Basically the planner should directly see the body of the function and
 since the algorithm parameter would be a constant, it should evaluate the
 CASE portion of the code and lookup the appropriate lower function just
 once. Speed comparison should be performed on a large table :)
 Would it make sense for ST_SimplifyVW to internally call
 ST_SetEffectiveArea and then the other still missing function that only
 filters out vertices where the M value is below a given value ?
 M vs Z: I didn't know geoJSON would put M value in the Z field, and what
 about a 4d geometry ? Which would would be dropped ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2227#comment:14>
