[postgis-tickets] [PostGIS] #3012: Calling ST_AsLatLonText in matviews causes unrestorable pg_dump (was: Calling PostGIS functions in matviews causes unrestorable pg_dump)
PostGIS trac at osgeo.org
Sun Jan 18 00:51:24 PST 2015
 Reporter:  jeffcasavant  |       Owner:  pramsey
     Type:  defect        |      Status:  new
 Priority:  medium        |   Milestone:  PostGIS PostgreSQL
Component:  postgis       |     Version:  2.1.x
 Keywords:                |
Changes (by robe):
  * milestone:  => PostGIS PostgreSQL
Comment:
 Yes it is related to #2485.  We can't solve the problem generically short
 of forcing everyone to install postgis in a specific schema and your
 assessment is not quite right.  Calling PostGIS functions in matviews is
 fine as long as the function you call doesn't call another PostGIS
 function.
 In your particular case, if you replace your view definition reference
 ST_AsLatLonText(geom)
 with
  ST_AsLatLonText(geom,'')
 then I bet it restores fine.
 When views are compiled, they actually do convert everything to schema
 qualified.  So the issue is that ST_AsLatLonText(geom)  does an
 unqualified schema call to ST_AsLatLonText(geom,'').
 In your case with ST_AsLatLonText the issue is we have two functions:
 st_aslatlontext(geometry, text) and ST_AsLatLonText(geometry).  So the one
 you are using calls the other one which is not schema qualified thus the
 error.
 We can fix this particular situation by dropping one of the functions and
 just have a default arg for the second.  I'll patch that in for 2.2.  I
 can't patch it in 2.1 since I would be removing a function definition.
 strk -- Why did we ever define two functions for ST_AsLatLonText?  when in
 my mind one with a default arg would have been sufficient, or was this
 before we switched to default args?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3012#comment:3>
