[postgis-tickets] [PostGIS] #3017: Passing RUNTESTFLAGS variable to "make check" breaks SFCGAL tests
PostGIS trac at osgeo.org
Wed Jan 21 07:14:05 PST 2015
 Reporter:  strk                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.6
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
 Run "make check RUNTESTFLAGS=-v" and all sfcgal tests are broken.
 This is due to the command-line passed variable overriding the Makefile-
 defined one which adds --sfcgal to the run_test call.
 See http://www.gnu.org/software/make/manual/make.html#Override-Directive
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3017>
