[postgis-tickets] [PostGIS] #3008: pgsql2shp version 2.1.4 crash
PostGIS trac at osgeo.org
Wed Jan 21 09:08:00 PST 2015
 Reporter:  nap2000    |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.1.6
Component:  postgis    |     Version:  2.1.x
 Keywords:  pgsql2shp  |
Comment(by robe):
 On closer inspection I see you were outputting a query and not the table
 1) does it crash if you output the whole table? and if not
 2) I can't make out your query can you attach the exact command you were
 running in a text file so it doesn't get mangled?
 I looked thru the logs of changes made to pgsql2shp and no changes as far
 as I can tell were made in 2.1.4 (last change was the one I made which
 would have been pushed in 2.1.3) http://trac.osgeo.org/postgis/ticket/2727
 So whatever you are seeing might be a change in a dependency or something
 further up in our code that pgsql2shp is using.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3008#comment:6>
