[postgis-tickets] [PostGIS] #3022: ValidateTopology error description order should match order of ids
PostGIS trac at osgeo.org
Sun Jan 25 10:42:36 PST 2015
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.7
Component:  topology  |     Version:  2.0.x
 Keywords:            |
 Regarding this:
 edge crosses node | node_id | edge_id # NOTE: should this be swapped?
 After closer inspection, I feel that yes we should swap and we should
 consider the order of topo element ids not matching the order of the error
 note a bug.  Reason being is that most people will assume that and will
 probbly never look at the docs to see its swapped.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3022>
