[postgis-tickets] [PostGIS] #3024: Get parallel some route.
PostGIS trac at osgeo.org
Tue Jan 27 07:17:47 PST 2015
 Reporter:  aikanaro  |       Owner:  pramsey
     Type:  defect    |      Status:  new
 Priority:  high      |   Milestone:
Component:  postgis   |     Version:  2.0.x
 Keywords:            |
 Hello,
 We use Postgre / Postgis database with ArcGIS Server and Desktop 10.2. All
 our data are inserted with keyword Postgis into our database.
 the table that has the trouble is a route table with 292 linestring. I
 need these routes is not bunk. I try to use ST_OffsetCurve function to do
 this. I found on the help and on a ticket that we must have geometry which
 is simple. More than 250 isn't. Is there any solution to fix the problem
 or to bypass the problem .
 Thanks for your work.
 Greating.
 ARNAUD Guillaume
 Sorry for my poor english, I'm french.
 "PostgreSQL 9.2.2, compiled by Visual C++ build 1600, 64-bit
 POSTGIS="2.0.4" GEOS="3.4.2-CAPI-1.8.2 r0" PROJ="Rel. 4.8.0, 6 March 2012"
 GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.7.8" LIBJSON="UNKNOWN"
 (core procs from "2.0.4" need upgrade) RASTER (raster procs from "2.0.4"
 need upgrade)"
 OS : Windows Server Standard SP 2
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3024>
