[postgis-tickets] [PostGIS] #3206: winnie crashing with topology ST_AddModeFace in C commit 9.3 w32 bit run (was: winnie crashing with topology ST_AddModeFace in C commit)
PostGIS trac at osgeo.org
Fri Jul 17 12:44:28 PDT 2015
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  blocker   |  Milestone:  PostGIS 2.2.0
 Component:  topology  |    Version:  trunk
Resolution:            |   Keywords:
Comment (by robe):
 Okay I just ran winnie's 9.3.9 64-bit and that seems fine so seems like
 this might be 32-bit only issue.
 run on below was fine.
 PostgreSQL 9.3.9, compiled by Visual C++ build 1600, 64-bit
   Postgis 2.2.0dev - r13808 - 2015-07-17 19:23:04
   scripts 2.2.0dev r13808
   GEOS: 3.5.0dev-CAPI-1.9.0 r4058
   PROJ: Rel. 4.8.0, 6 March 2012
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3206#comment:1>
