[postgis-tickets] [PostGIS] #3143: 32-bit cunit check crashing
PostGIS trac at osgeo.org
Tue Jun 2 18:38:33 PDT 2015
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.2.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by darkblueb):
 tested multiple runs of ''make check'' in the same 32bit VM, with r13601;
 crash in lwlinearreferencing.c has not occurred at all; tests are running
 to completion every time
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3143#comment:11>
