[postgis-tickets] [PostGIS] #3154: make dist should generate the pom.xml
PostGIS trac at osgeo.org
Fri Jun 12 12:06:30 PDT 2015
  Reporter:  robe    |      Owner:  robe
      Type:  defect  |     Status:  new
  Priority:  medium  |  Milestone:  PostGIS 2.1.8
 Component:  java    |    Version:  2.1.x
Resolution:          |   Keywords:
Comment (by robe):
 I had attempted to fix the issue at r13634  but guess I broke things.
 To which strk put in a complaint at #3160
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3154#comment:2>
