[postgis-tickets] [PostGIS] #3167: Windows build broken, lwin_geojson.c undefined reference to json_..
PostGIS trac at osgeo.org
Tue Jun 16 15:41:19 PDT 2015
  Reporter:  robe     |      Owner:  strk
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 2.2.0
 Component:  postgis  |    Version:  trunk
Resolution:  fixed    |   Keywords:
Comment (by robe):
 oh so 2 cents wasn't good enough, you had to give us 3 additional cents :)
 Anyway I still have to try building without libjson to make sure that is
 the only spot at fault and if I understand you correctly, I need to
 perhaps rebuild json with (allowing dynamic and static creation) and do a
 -static somewhere for liblwgeom so I get my preferred static behavior, and
 then we can put back that line so you can have your preferred dynamic
 back.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3167#comment:11>
