[postgis-tickets] [PostGIS] #2734: TIGER geocoder geocode_intersection gives no results with omitted zipcode
PostGIS trac at osgeo.org
Thu Jun 25 11:38:35 PDT 2015
  Reporter:  futuraprime     |      Owner:  robe
      Type:  defect          |     Status:  closed
  Priority:  high            |  Milestone:  PostGIS 2.2.0
 Component:  tiger geocoder  |    Version:  2.1.x
Resolution:  fixed           |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 Okay should be much improved at r13705 .  I increased limit of records
 returned at substeps and even with that this particular address returns in
 about the same time with/without zip (a little of 1 second with a couple
 of states loaded).
 I'm not going to bother backporting though since it may have some
 performance consequences for other common streets.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2734#comment:8>
