[postgis-tickets] [PostGIS] #3182: update docs and configure to reflect SFCGAL 1.1+ is required to build with SFCGAL
PostGIS trac at osgeo.org
Fri Jun 26 02:12:47 PDT 2015
  Reporter:  robe     |      Owner:  colivier
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 2.2.0
 Component:  sfcgal   |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 confirmed configure change traps lower now.  Get this from winnie now.
 I'll check again after I upgrade sfcgal:
 configure: error: PostGIS requires SFCGAL >= 1.1.0 (found 1.0.5)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3182#comment:6>
