[postgis-tickets] [PostGIS] #3069: Some functions inject a bounding box to POINT geometries
    trac at osgeo.org
    Wed Mar  4 08:45:00 PST 2015
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.7
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
 I've found that some functions result in points being equipped with a
 bounding box cache. I think this should be avoided by policy, shouldn't it
 Example:
 =# select st_summary(ST_FlipCoordinates('POINT(0 0)'));
 Point[B]
 =# select st_summary(ST_Reverse('POINT(0 0)'));
 Point[B]
 =# select st_summary(postgis_noop('POINT(0 0)'::geometry));
 Point[B]
 Actually I start thinking if _all_ the functions would be doing that...
 Standard input functions, correctly, do not add a bbox cache:
 =# select st_summary('POINT(0 0)'::geometry);
 Point[]
 =# select st_summary(st_geomfromtext('POINT(0 0)'));
 Point[]
 I've tested 1.5 and it is NOT affected. 2.0 branch is affected.
 I'm considering this high because grows the size of POINT layers by a big
 amount (48 bytes instead of 21 for a 2D point)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3069>
