[postgis-tickets] [PostGIS] #3105: sfcgal legacy test via extension: ERROR: attempt to redefine parameter "postgis.backend
PostGIS trac at osgeo.org
Mon May 4 03:12:36 PDT 2015
"postgis.backend
  Reporter:  strk    |      Owner:  colivier
      Type:  defect  |     Status:  new
  Priority:  medium  |  Milestone:  PostGIS 2.2.0
 Component:  sfcgal  |    Version:  trunk
Resolution:          |   Keywords:
Comment (by strk):
 Got it, the "legacy.sql" script loads the "legacy.sql" enabled script from
 offline, which in turn loads the shared object from offline. There's then
 a clash of libraries between the online one and the offline one.
 How should "legacy" be tested online ?
 @robe: how do you want people to enable "legacy" when using an extension ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3105#comment:3>
