[postgis-tickets] [PostGIS] #3108: ST_SubDivide leaves pockets
PostGIS trac at osgeo.org
Thu May 7 07:15:51 PDT 2015
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 2.2.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by strk):
 The code counts the number of vertices that fall within the clipping box.
 In your case, there are NO vertices in the box, right ?
 In that case, the code checks if the polygon contains one corner of the
 box and if it does, it returns a fully filled box, otherwise it returns
 nothing.
 Well, in your cases the box contains NO vertices but it still cuts the
 polygon, so it's neither a full solid nor a missing. If this analysis is
 correct, the code is bogus.
 It will be a fun exercise at finding the smallest input that can reproduce
 the problem.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3108#comment:7>
