[postgis-tickets] [PostGIS] #3120: Improve upgrade tester by adding some postgis objects before upgrade
PostGIS trac at osgeo.org
Mon May 18 00:44:08 PDT 2015
  Reporter:  strk                   |      Owner:  strk
      Type:  enhancement            |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 2.2.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:  fixed                  |   Keywords:
Changes (by strk):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 r13518 in trunk.
 For core, only creates a table with a geometry and a geography fields (no
 AddGeometryColumns, no constraints).
 For raster, it adds a raster column to the table and add constraints (no
 parameters to the function).
 For topology it creates a topology (no parameters to CreateTopology).
 Enhancements can use other tickets.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3120#comment:1>
