[postgis-tickets] [PostGIS] #3125: ST_LineLocatePoint garden crasher
PostGIS trac at osgeo.org
Sat May 23 20:45:10 PDT 2015
  Reporter:  robe      |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS 2.1.8
 Component:  postgis   |    Version:  2.1.x
Resolution:            |   Keywords:
Description changed by robe:
Old description:
> This issue looks like it probably got introduced with PostGIS 2.1.7
> (since that exhibits the issue and so does 2.1 and trunk).
> SELECT ST_LineLocatePoint(ST_MakeLine('POINT(1 2)'::geometry, 'POINT
> EMPTY'::geometry), ST_Point(-11,40));
> What is also interesting about this problem, is I can't make a linestring
> from the wkt of it:
> {{{ -- gives ERROR:  geometry requires more points
> SELECT 'LINESTRING(1 2)'::geometry;
> But am able to using ST_MakeLine or the canonical form
> SELECT ST_MakeLine('POINT(1 2)'::geometry, 'POINT EMPTY'::geometry);
> SELECT '010200000001000000000000000000F03F0000000000000040'::geometry;
> Which I guess is okay since we want people to be able to restore corrupt
> data though not necessarily create such a thing.
New description:
 This issue looks like it probably got introduced with PostGIS 2.1.7 (since
 that exhibits the issue and so does 2.1 and trunk), but my 2.1.5 does not
 (and just throws a
 ERROR:  getPoint4d_p: point offset out of range
 ********** Error **********
 error
 from the wkt of it:
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3125#comment:1>
