[postgis-tickets] [PostGIS] #3356: geometry to geography cast, always adds a box even for 2 point linestrings and single points
PostGIS trac at osgeo.org
Mon Nov 2 23:59:52 PST 2015
and single points
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.1.9
 Component:  postgis  |    Version:  2.1.x
Resolution:           |   Keywords:
Comment (by robe):
 pramsey want to check my work on this to make sure I did the right thing.
 I changed to use both for geography_from_geometry and geography_segmentize
  gserialized_geography_from_lwgeom(lwgeom, -1);
 so it behaves just like when you cast from text,
 instead of that long painful list of add/drop/set_geodetic.
 If it looks okay to you I will backport to 2.2.  Not sure it makes sense
 for 2.1.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3356#comment:3>
