[postgis-tickets] r14352 - cleanup whitespace and comments
Regina Obe lr at pcorp.us
Tue Nov 3 02:54:45 PST 2015
Author: robe
Date: 2015-11-03 02:54:45 -0800 (Tue, 03 Nov 2015)
New Revision: 14352
   trunk/postgis/geography_inout.c
   trunk/postgis/geography_measurement.c
references #3356 (for 2.3 branch)
references #3355 (for 2.3 branch for segmentize)
Modified: trunk/postgis/geography_inout.c
--- trunk/postgis/geography_inout.c	2015-11-03 10:31:51 UTC (rev 14351)
+++ trunk/postgis/geography_inout.c	2015-11-03 10:54:45 UTC (rev 14352)
@@ -598,19 +598,16 @@
-	/* Recalculate the boxes after re-setting the geodetic bit */
+	/* force recalculate of box by dropping */
 	lwgeom_drop_bbox(lwgeom);
 	g_ser = gserialized_geography_from_lwgeom(lwgeom, -1);
-	** Replace the unaligned lwgeom with a new aligned one based on GSERIALIZED.
 	lwgeom_free(lwgeom);
 	PG_FREE_IF_COPY(geom, 0);
 	PG_RETURN_POINTER(g_ser);
 PG_FUNCTION_INFO_V1(geometry_from_geography);
Modified: trunk/postgis/geography_measurement.c
--- trunk/postgis/geography_measurement.c	2015-11-03 10:31:51 UTC (rev 14351)
+++ trunk/postgis/geography_measurement.c	2015-11-03 10:54:45 UTC (rev 14352)
@@ -1066,21 +1066,21 @@
 	GSERIALIZED *g2 = NULL;
 	double max_seg_length;
 	uint32_t type1;
 	/* Get our geometry object loaded into memory. */
 	g1 = PG_GETARG_GSERIALIZED_P(0);
 	type1 = gserialized_get_type(g1);
 	/* Convert max_seg_length from metric units to radians */
 	max_seg_length = PG_GETARG_FLOAT8(1) / WGS84_RADIUS;
 	/* We can't densify points or points, reflect them back */
 	if ( type1 == POINTTYPE || type1 == MULTIPOINTTYPE || gserialized_is_empty(g1) )
 		PG_RETURN_POINTER(g1);
 	/* Deserialize */
 	lwgeom1 = lwgeom_from_gserialized(g1);
 	/* Calculate the densified geometry */
 	lwgeom2 = lwgeom_segmentize_sphere(lwgeom1, max_seg_length);
@@ -1093,7 +1093,7 @@
 	lwgeom_free(lwgeom1);
 	lwgeom_free(lwgeom2);
 	PG_FREE_IF_COPY(g1, 0);
 	PG_RETURN_POINTER(g2);
