[postgis-tickets] [PostGIS] #3356: geometry to geography cast, always adds a box even for 2 point linestrings and single points
PostGIS trac at osgeo.org
Tue Nov 3 07:26:09 PST 2015
and single points
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.1.9
 Component:  postgis  |    Version:  2.1.x
Resolution:           |   Keywords:
Comment (by robe):
 aha - found it - add box is happening via geography_serialize via the
 gserialized_from_lwgeom call.  So it seems our change to not add a box to
 point and 2 point linestring for geometry inadvertently affected
 geography_from_text?
 http://postgis.net/docs/doxygen/2.3/da/d21/g__serialized_8c_a0b9fd37dce2089c4fecb8a23ed102323.html#a0b9fd37dce2089c4fecb8a23ed102323
 shouldn't that be changed then to also consider if a geodetic flag is set
 and just do the right thing?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3356#comment:10>
