[postgis-tickets] r14373 - Fix toTopoGeom loss of low-id primitives from TopoGeometry definition
Sandro Santilli strk at keybit.net
Sat Nov 7 02:28:22 PST 2015
Author: strk
Date: 2015-11-07 02:28:22 -0800 (Sat, 07 Nov 2015)
New Revision: 14373
   branches/2.1/NEWS
   branches/2.1/topology/sql/topogeometry/totopogeom.sql.in
   branches/2.1/topology/test/regress/totopogeom.sql
   branches/2.1/topology/test/regress/totopogeom_expected
Affects toTopoGeom on including edge with id=2 and face with id=3
Includes tests.
Fixes #3359
Modified: branches/2.1/NEWS
--- branches/2.1/NEWS	2015-11-07 10:24:12 UTC (rev 14372)
+++ branches/2.1/NEWS	2015-11-07 10:28:22 UTC (rev 14373)
@@ -3,7 +3,6 @@
  * Bug Fixes *
-  - #3351, set endnodes isolation on ST_RemoveIsoEdge
   - #3198, ST_AddEdgeModFace docs report wrong side of new face
   - #3196, do not let DropTopology drop non-topology schemes
   - #3222, Fix uninitialized stddev in stats computation
@@ -11,8 +10,12 @@
   - #3245, Ensure lwgeom/geos returns are fully owned
   - #3281, Do not export liblwgeom symbols from the PostgreSQL module
   - #3280, Fix topology import of almost collinear linestrings
+  - #3351, Set endnodes isolation on ST_RemoveIsoEdge
   - #3355, Fix geography ST_Segmentize() does not add geodetic box
-  			ST_Intersects and other relationship functions always return false as result.
+           ST_Intersects and other relationship functions
+           always return false as result.
+  - #3359, Fix toTopoGeom loss of low-id primitives from TopoGeometry
+           definition
 PostGIS 2.1.8
 2015/07/07
Modified: branches/2.1/topology/sql/topogeometry/totopogeom.sql.in
--- branches/2.1/topology/sql/topogeometry/totopogeom.sql.in	2015-11-07 10:24:12 UTC (rev 14372)
+++ branches/2.1/topology/sql/topogeometry/totopogeom.sql.in	2015-11-07 10:28:22 UTC (rev 14373)
@@ -10,6 +10,8 @@
+/* #define POSTGIS_TOPOLOGY_DEBUG 1 */
 --  Convert a simple geometry to a topologically-defined one
@@ -23,12 +25,7 @@
 DECLARE
   layer_info RECORD;
   topology_info RECORD;
-  rec RECORD;
-  rec2 RECORD;
   tg topology.TopoGeometry;
-  elems INT[][];
-  elem INT[];
-  sql TEXT;
   typ TEXT;
 BEGIN
@@ -135,8 +132,8 @@
   rec RECORD;
   rec2 RECORD;
-  elem INT[];
-  elems INT[][];
+  elem TEXT;
+  elems TEXT[];
   sql TEXT;
   typ TEXT;
   tolerance FLOAT8;
@@ -249,10 +246,11 @@
          topology.topogeo_addPolygon(atopology, rec.geom, tolerance)
        END as primitive
     LOOP
-      elem := ARRAY[rec.dims+1, rec2.primitive];
+      elem := ARRAY[rec.dims+1, rec2.primitive]::text;
       IF elems @> ARRAY[elem] THEN
 #ifdef POSTGIS_TOPOLOGY_DEBUG
 RAISE DEBUG 'Elem % already in %', elem, elems;
+RAISE DEBUG '% @> ARRAY[%] returned true', elems, elem;
 #endif
       ELSE
Modified: branches/2.1/topology/test/regress/totopogeom.sql
--- branches/2.1/topology/test/regress/totopogeom.sql	2015-11-07 10:24:12 UTC (rev 14372)
+++ branches/2.1/topology/test/regress/totopogeom.sql	2015-11-07 10:28:22 UTC (rev 14373)
@@ -200,6 +200,26 @@
   WHERE t.id = -1 AND r.layer_id = 4 AND r.topogeo_id = id(t.g)
   GROUP BY id(t.g), st_area(t.g);
+-- http://trac.osgeo.org/postgis/ticket/3359
+-- NOTE: requires identifier of the second edge to be 2
+TRUNCATE tt.relation CASCADE;
+TRUNCATE tt.edge_data CASCADE;
+TRUNCATE tt.node CASCADE;
+DELETE FROM tt.face WHERE face_id > 0;
+SELECT '#3359.setval',
+       setval('tt.edge_data_edge_id_seq', 1, false),
+       -- face_id is intentionally set to 2
+       setval('tt.face_face_id_seq', 2, false),
+       setval('tt.node_node_id_seq', 1, false);
+SELECT '#3359.line.1', ST_Length(toTopoGeom('LINESTRING (0 0,1 0)'
+::geometry, 'tt', 3));
+SELECT '#3359.line.2', ST_Length(toTopoGeom('LINESTRING (0 0,1 0,1 1)'
+SELECT '#3359.area.1', ST_Area(toTopoGeom('POLYGON ((0 0,1 0,1 1,0 1,0 0))'
+::geometry, 'tt', 4));
+SELECT '#3359.area.2', ST_Area(toTopoGeom('POLYGON ((0 0,1 0,1 2,0 2,0 0))'
 DROP TABLE tt.f_coll;
 DROP TABLE tt.f_areal;
 DROP TABLE tt.f_lineal;
Modified: branches/2.1/topology/test/regress/totopogeom_expected
--- branches/2.1/topology/test/regress/totopogeom_expected	2015-11-07 10:24:12 UTC (rev 14372)
+++ branches/2.1/topology/test/regress/totopogeom_expected	2015-11-07 10:28:22 UTC (rev 14373)
@@ -44,4 +44,9 @@
 tgup1.1|5|100|1
 tgup1.2|5|200|2
 tgup1.3|5|200|4
+#3359.setval|1|2|1
+#3359.line.1|1
+#3359.line.2|2
+#3359.area.1|1
+#3359.area.2|2
 Topology 'tt' dropped
