[postgis-tickets] [PostGIS] #3082: Error soft-upgrading from 2.1 to 2.2
PostGIS trac at osgeo.org
Wed Nov 11 00:45:23 PST 2015
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  reopened
  Priority:  medium                 |  Milestone:  PostGIS 2.2.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:
Comment (by strk):
 Did you get to 2.2.0dev in an upgrade from 2.1.0 ?
 I suspect you had a broken 2.2.0dev, basically, due to this bug.
 The upgrade script won't add it from 2.2.0 to 2.2.0, but it should
 add it from 2.1.x to 2.2.0. Try sourcing rtpostgis_upgrade.sql from
 2.1.0 first and then get back to this 2.2.0 one.
 Or you could manually edit the rtpostgis_upgrade.sql from 2.2.0
 to tweak the conditional summarystats addition:
  -- Type summarystats -- LastUpdated: 200
  DO LANGUAGE 'plpgsql'
  $postgis_proc_upgrade$
  BEGIN
    IF 200 > version_from_num
  OR version_from_num IN ( 201 )     FROM _postgis_upgrade_info
    THEN
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3082#comment:11>
