[postgis-tickets] [PostGIS] #3369: winnie failing after remove points committ
PostGIS trac at osgeo.org
Sat Nov 14 17:24:18 PST 2015
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  PostGIS 2.2.1
Component:  buildbots  |    Version:  2.2.x
 Keywords:             |
 As noted in #3367, winnie's 9.4 w32 (i'll check if its the same iwth w64),
 started failing, unable to compile in Cunit
 at  r14376
 with error:
 *** Warning: Linking the executable cu_tester against the loadable module
 *** libSFCGAL.dll is not portable!
 libtool: link: i686-w64-mingw32-gcc -g -O2 -Wall -Wmissing-prototypes
 -I/projects/geos/rel-3.5.0w32gcc481/include
 -I/projects/proj/rel-4.9.1w32gcc481/include
 -I/projects/postgresql/rel/pg9.4w32gcc481/include -I/projects/rel-
 libiconv-1.13.1w32gcc481/include -I.. -Ie:/jenkins/CGAL/rel-
 sfcgal-1.2w32gcc481/include -DHAVE_SFCGAL -o .libs/cu_tester
 cu_algorithm.o cu_bytebuffer.o cu_buildarea.o cu_clean.o cu_print.o
 cu_misc.o cu_ptarray.o cu_geodetic.o cu_geos.o cu_geos_cluster.o cu_tree.o
 cu_measures.o cu_effectivearea.o cu_node.o cu_clip_by_rect.o cu_libgeom.o
 cu_split.o cu_stringbuffer.o cu_triangulate.o cu_homogenize.o
 cu_force_sfs.o cu_out_twkb.o cu_out_wkt.o cu_out_wkb.o cu_out_gml.o
 cu_out_kml.o cu_out_geojson.o cu_out_svg.o cu_out_encoded_polyline.o
 cu_surface.o cu_out_x3d.o cu_in_geojson.o cu_in_twkb.o cu_in_wkb.o
 cu_in_wkt.o cu_in_encoded_polyline.o cu_varint.o cu_unionfind.o
 cu_tester.o cu_sfcgal.o  ../.libs/liblwgeom.a
 -L/projects/postgresql/rel/pg9.4w32gcc481/lib
 -L/projects/gdal/rel-2.0.1w32gcc481/lib -L/projects/rel-
 libiconv-1.13.1w32gcc481/lib -L/projects/geos/rel-3.5.0w32gcc481/lib
 -L/projects/proj/rel-4.9.1w32gcc481/lib
 -L/projects/json-c/rel-0.12w32gcc481/lib -Le:/jenkins/CGAL/rel-
 sfcgal-1.2w32gcc481/lib
 /projects/proj/rel-4.9.1w32gcc481/lib/libproj.dll.a -lpthread
 /projects/json-c/rel-0.12w32gcc481/lib/libjson-c.a -lgeos_c
 /mingw/i686-w64-mingw32/lib/libcunit.a
 -L/sources/CUnit-2.1-2/CUnit/Sources e:/jenkins/CGAL/rel-
 sfcgal-1.2w32gcc481/lib/libSFCGAL.dll
 Makefile:82: recipe for target `check' failed
 make[2]: *** [check] Error 53
 make[2]: Leaving directory
 `/projects/postgis/branches/2.2/liblwgeom/cunit'
 Makefile:186: recipe for target `check' failed
 make[1]: *** [check] Error 2
 make[1]: Leaving directory `/projects/postgis/branches/2.2/liblwgeom'
 GNUmakefile:16: recipe for target `check' failed
 make: *** [check] Error 1
 The 2.3 build works fine though, so could very well be something I changed
 between Nov 7th and Nov 10th and not related to this.
 Given that doing the same 9.4 32-bit run on my pc which is more or less
 setup the same as winnie, suggests it's just a configuration issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3369>
