[postgis-tickets] [PostGIS] #3324: DB Crash - Status Stopped - ST_StraightSkeleton and ST_ApproximateMedialAxis
PostGIS trac at osgeo.org
Mon Nov 16 07:42:19 PST 2015
  Reporter:  jvidin    |      Owner:  colivier
      Type:  defect    |     Status:  closed
  Priority:  critical  |  Milestone:  PostGIS SFCGAL
 Component:  sfcgal    |    Version:  2.2.x
Resolution:  fixed     |   Keywords:  DB Crash
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 This should no longer crash in SFCGAL 1.2.1+.  Note that winnie's
 experimental 2.2.1dev and 2.3.0dev builds against SFCGAL master, so issue
 should be fixed on that.  The SFCGAL binaries should work fine against
 PostGIS 2.2.0 if you just want to replace the binaries.  Though admittedly
 I haven't had a chance to test them.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3324#comment:9>
