[postgis-tickets] [PostGIS] #3370: Crash in check_raster_columns pgis 2.0 pgsql 9.4
PostGIS trac at osgeo.org
Tue Nov 17 00:35:45 PST 2015
  Reporter:  strk     |      Owner:  dustymugs
      Type:  defect   |     Status:  closed
  Priority:  high     |  Milestone:  PostGIS 2.0.8
 Component:  raster   |    Version:  2.0.x
Resolution:  wontfix  |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => wontfix
Comment:
 strk we don't support PostgreSQL 9.4 on PostGIS 2.0.  PostgreSQL 9.4 needs
 to run on PostGIS 2.1+.  So if you are seeing an issue there, it's not
 relevant.
 I've marked this as a won't fix.
 See our support matrix.
 https://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS
 see even says in our installation docs:
 http://postgis.net/docs/manual-2.0/postgis_installation.html#idp53201632
 9.2 is last supported on 2.0 - newer versions need to use PostGIS 2.1+
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3370#comment:1>
